TXDTR #8 Forum for the Texas chapter #8
NTDTR May GTG
Old May 20, 2008 | 12:58 PM
crobtex's Avatar
NTDTR #8 May/June GTG
By popular demand, we will be going back to The Ranch after the races in Denton on the 31st.
If you've been there, you know what you need to bring.
I don't plan on cooking, but if someone else wants too, feel free to do so.
Old May 20, 2008 | 01:28 PM
RowJ's Avatar
Excellent! I'll be there!
I can live with a stop in Van Alystene for Burger King/Subway.
RJ
Old May 20, 2008 | 04:53 PM
13FOX's Avatar
RJ bring the bumper! I'll bring the tool tray and hardwarer. I'll be by after me and the girl get done at the convention.
Charlie, NO you cant take her to see the horses!!!!
Old May 20, 2008 | 05:49 PM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
MMMMMMMM still has that new thread smell
i bet 13FOX can make that go away HAHAHA.
Old May 20, 2008 | 06:01 PM
crobtex's Avatar
Don't even start!
Old May 21, 2008 | 06:45 PM
13FOX's Avatar
I acually had 6 tacos for lunch with the hottest friggin sauce I ever ate!! I blew it up during the last 4 hours of class. Ran one instructor out!
MAX can you send me that video in .wmv file please.
Charile you have a pm.
Old May 21, 2008 | 06:47 PM
13FOX's Avatar
Originally Posted by crobtex
Don't even start!
Can you make chili again?? PLEASE!!!!!?????
Old May 21, 2008 | 08:05 PM
crobtex's Avatar
Nope, just gonna lay back and watch this go round.
Old May 22, 2008 | 05:49 AM
bnold's Avatar
Whew... $900 bones for new AC compressor, orfice tube, dryer, etc...
Been without AC in the old girl since November... Have to fire her up to work this weekend, needed some cool air!
Old May 22, 2008 | 08:28 AM
RowJ's Avatar
Ouch! Don't hear that problem very often.... thank god.
RJ
Old May 22, 2008 | 09:47 AM
bigredBCS's Avatar
I think my ac is on its way out! Sometimes it won't kick in and now I have a wierd squel when the ac is on and the annoying 2nd gen chirp when turning the truck off. Hopefully its just a belt or something
Old May 22, 2008 | 09:53 AM
AggieJustin's Avatar
I think the next of my A/C adventures will involve pulling the HVAC housing to check the blend door. The air I get is pretty cool, but not as cold as I've heard other people report. And as I start turning the temp dial toward hot, it gets hot quick. I'm thinking that my blend door isn't aligned properly and even on full cold, I'm still getting some air passed over the heater coil.
I've considered shutting off the flow of coolant through the heater coil to see if it helps matters any, but I've heard conflicting reports on whether this is doable/advisable or not.
Old May 22, 2008 | 10:01 AM
RowJ's Avatar
Originally Posted by bigredBCS
... and the annoying 2nd gen chirp when turning the truck off.
Probably built your truck with a left over 02, 5.9L. THAT's why it's so fast!
RJ
Old May 22, 2008 | 03:05 PM
crobtex's Avatar
Mine has been leaking a little freon. I added a can this week for the 3rd year in a row. My little probe thermometer show almost a 20* drop after adding. Has anyone tried the freon with sealer or oil?
Old May 22, 2008 | 03:20 PM
Diesel-Dan's Avatar
My suggestion is to find the area of the leak and then try the snake...er..um...seal oil in your R-134a...........
Its a temporary fix....my suggestion is to find the issue and fix it correctly by replacing the o-ring, line, or component that is causing the issue.
Look for oil residue on any lines (Especially at junctions). Look around your air box…at the high pressure line….they can rub and leak there. Check your condenser on the fnt of the truck for punctures. If you find nothing…might be the evaporator core in the dash…..(which that is where I think mine is leaking). Other than getting some one to pull the system down to 0 PSI and capture the R-134a. Then pulling a vacuum after the work is done, AC work is pretty simple (Pending you don’t have to mess with the compressor or pull the dash.
