m&h timing spacer-anybody get it to run right with ksb?
Old 10-26-2014, 05:02 PM
big stinky's Avatar
As the title says, looking for other folks that have gotten this device to work with the ksb. I am interested in your initial timing settings, and power screw settings.
Run down on my end: installed spacer with full pump rebuild. Runs terrible with ksb power off (can't turn it on on initial start up, non i/c pump)
Just advanced the timing to the head today, and turned up the power screw, seems to start better but does the lope when it's warm now? (First drive with advanced timing, may change over the next couple days) been inconsistent starting since I've installed it.
Anybody have any lift numbers or a specific spacer washer setup that worked for them that I can try before I throw this 100 dollar aluminum ring in the ocean?
Old 10-26-2014, 05:49 PM
cougar's Avatar
How does it run without it?
Old 10-26-2014, 07:00 PM
1st Generation Admin
BC847's Avatar
Take the spacer kit off completely (back to stock) and ensure the rebuilt pump works right.
Old 10-26-2014, 08:54 PM
big stinky's Avatar
Pump works right already been done. Should have mentioned that.
With the pump fully advanced on the stock tooth it starts a lot better. (With spacer)
Old 10-27-2014, 06:51 AM
Received 1,332 Likes on 862 Posts
With My spacer on my 93 motor, I can not run the KSB at all. If I hook it up I run so much timing that I loose almost all my bottom end power. Can barely crawl up a hill!
Old 10-27-2014, 09:53 AM
BILTIT's Avatar
I run the spacer with my ksb functional, Pump timing is stock though.
No issues, works great.
Old 10-27-2014, 11:21 AM
j_martin's Avatar
I think the basic idea of the dynamic timing mod is that you can then run the pump at stock timing, and not lose your low end grunt, but gain on the top end as the timing is advanced with RPM. If you use both the dynamic timing and advance the pump, you can go over the hill on the low end.
If just putting the M&H timing in caused the low end to go way over advanced, something's wrong with the install.
Old 10-27-2014, 09:37 PM
My IP has no mods....all stock with just a re-seal. I had an air intake temp sensor for the KSB that was faulty, replaced it, Still too much advance. I figure either I installed it wrong, don't think so, but anything is possible. Or my KSB is faulty.
I may pop the spacer out and run it that way to verify that the KSB is either good or not. If it's bad I have a spare KSB I will swap on and see what happens then.
Old 10-28-2014, 08:33 AM
mknittle's Avatar
That's way I understand it. that way you get a wider torque band.
Old 11-01-2014, 03:22 PM
big stinky's Avatar
Thanks for the replies guys.
It appears you are all running intercooled pumps? Anybody have the spacer in a non i/c pump?
the.beard
12-13-2014 11:55 AM
bigragu
09-25-2014 06:27 AM
ClassA4x4
10-13-2013 10:23 AM
Wettstein
10-24-2010 09:30 AM
59FORD
02-26-2007 06:44 AM
Quick Reply: m&h timing spacer-anybody get it to run right with ksb?
