Got the HE351VE on
Old 09-05-2009, 10:56 AM
  #76
aborgardt's Avatar
Well, I think I finally got it. It's a little laggy off the line, about the same as the other turbo, but when it lites, it lites.....I put a 12.5# spring on it, so the lever doesnt even start to move until 15psi, and then it doesn't move very far. I'm seeing a little more than 30psi, which, I dont think is bad since i have no programmer. EGT's are back check. It runs a little hotter on acceleration, but cruising it is about 50* cooler and I cant get it over 1250* no matter how hard i try. I definitely like it more than the other. Now all I need is to add the on board air to make the exhaust brake work.
Old 09-09-2009, 03:04 PM
  #77
TRENDZ's Avatar
I have a few pics here to show how I adapted the turbo to the manifold without an adapter...
Attached Thumbnails Got the HE351VE on-vgt-manifold-001.jpg   Got the HE351VE on-vgt-manifold-002.jpg   Got the HE351VE on-vgt-manifold-003.jpg   Got the HE351VE on-vgt-manifold-004.jpg   Got the HE351VE on-vgt-manifold-005.jpg
Old 09-09-2009, 03:06 PM
  #78
TRENDZ's Avatar
More pics.
Attached Thumbnails Got the HE351VE on-vgt-manifold-006.jpg   Got the HE351VE on-vgt-manifold-007.jpg   Got the HE351VE on-vgt-manifold-009.jpg   Got the HE351VE on-vgt-manifold-010.jpg   Got the HE351VE on-vgt-manifold-011.jpg
Old 09-27-2009, 12:25 AM
  #79
12valve's Avatar
i like that!
Im not sure if i totally understand how you did it!
how did you close the existing holes in the turbo? (with what?)
btw its nice to see you can moachine the manifold to put a nut behind it
Old 09-27-2009, 02:33 AM
  #80
TRENDZ's Avatar
I drilled the existing holes to accept a 1/4" pipe tap, threaded the housing, than used 1/4" pipe plugs (there's one laying on the housing in one of the pictures)to fill the holes. This allows you to re-drill and tap the housing to a standard t3 bolt pattern and install the studs.
Be very carefull when grinding the manifold. There is JUST enough material in that area for a standard 3/8" bolt(9/16" hex) No room to spare there, when I was finished, the wall thickness was only 1/8".
Old 09-28-2009, 11:38 AM
  #81
12valve's Avatar
thanks! i see you have a 12v manifold, i wonder if the 24v manifold is worse?
Old 10-06-2009, 07:26 PM
  #82
Number47's Avatar
Originally Posted by TRENDZ
More pics.
how did you reclock the center section to the exhaust housing with the vanes on the nozzle indexing into the exhaust housing?
Old 10-06-2009, 10:33 PM
  #83
speed75's Avatar
the internal female part turns in the houseing
Old 10-07-2009, 04:18 AM
  #84
Jungle's Avatar
Nice job!!!!
Old 10-07-2009, 06:13 PM
  #85
Number47's Avatar
did you have to drill out the pins?
Old 10-07-2009, 06:16 PM
  #86
TRENDZ's Avatar
Yes, the exhaust housing has a reciever ring for the vanes that rotates 360 degrees. The housing is clockable in any position. It is a bit tricky to get it together after taking it off and rotating it, but far from impossible.
Old 10-07-2009, 06:19 PM
  #87
TRENDZ's Avatar
I just pulled out the pins with a side cutter... very easy to do.
tmiller24 (05-29-2021)
Old 10-07-2009, 07:41 PM
  #88
PapeCAT's Avatar
The pins just pulled out with a pair of pliers for me too, no grinding necessary and very easy. This was on my HE351CW though.
Old 10-12-2009, 07:51 PM
  #89
12valve's Avatar
I had my 98 24v at the track yesterday.
here's a Video
It ran 8.87 1/8 mile
Its got jammer injectors and a juice box and HE351VE
Old 10-12-2009, 07:57 PM
  #90
TRENDZ's Avatar
Are you controlling the turbo or is it in a fixed position?
Quick Reply: Got the HE351VE on
