G56 2wd into a W250
Old 10-12-2014, 03:38 PM
bobva's Avatar
G56 2wd into a W250
I can get a G56 2wd for a good price.
Whats it take to put it in my W250?
Old 10-12-2014, 03:51 PM
Received 1,332 Likes on 862 Posts
This thread over on another cummins board is pretty thorough...
http://www.cumminsforum.com/forum/89...-finished.html
And this one...
http://www.cumminsforum.com/forum/89...-g56-swap.html
Old 10-12-2014, 06:57 PM
bobva's Avatar
Thank you TC
Those threads answered a lot of questions.
Now I have a question I got the 3.08 gears in my axles with the Getrag I basicly have no granny gear and a very fast reverse (I put transfer in to low for when really needed) and no need for 5th below 70mph
With the the G56 will I have a lower 1st and slower reverse than I have now? I'm think yes
I'm not real good at reading this gear chart
Gear G-56 AD G-56 AE G-360 (5 Spd.) NV 4500
1 6.29 5.94 5.53 5.61
2 3.48 3.28 3.02 3.04
3 2.10 1.98 1.60 1.67
4 1.38 1.31 1.00 1.00
5 1.00 1.00 0.77 0.73
6 0.79 0.74 N/A N/A
Rev 6.29 5.42 5.03 5.61 or 5.04
O/D-F/D Ratio@ 3.54 R/A
2.89 2.62 2.73 2.58
Old 10-13-2014, 12:20 AM
Yes the G56 will have a slower gear for 1st and Reverse,
G56 AD = 6.29,
G56 AE = 5.94
Getrag (G360) = 5.53.
Read them as a gear ratio...higher the number, slower the movement.
I think it's a typo for the G360 on that chart...but generally the 1st and reverse are the same gear ratio.
Old 10-13-2014, 08:19 AM
Philip's Avatar
When your looking at a G56 on the ID plate under model it says G56. If it has a -x with the X being a number. that is the early .79 OD trans. If it says G56-R its a later trans with the .74 OD and high geared 1st and reverse.
Find a -X model. That .74 OD is just about to high.
The only difference between 2WD and $X$ is the bolted on drive shaft adapter flange. Unbolt it and the 205 bolts right on.
Old 10-13-2014, 10:10 AM
bobva's Avatar
Thanks Philip i did read your thread with a fine tooth comb and came to the conclusion that I will be needing the older AD 05-07.5 G-56 lower geared.
Unfortunately the G-56 I found at a fair price is advertised as a 08 but that's not stopping me to look at it and see if it has the X.
Old 10-13-2014, 12:40 PM
bobva's Avatar
Found this thread also.
http://www.turbodieselregister.com/t...t-Gen-G56-Swap
Old 10-13-2014, 01:21 PM
bobva's Avatar
Phillip
are you talking about the X in the var #?
http://www.cumminsforum.com/forum/3r...der-ad-ae.html
Old 10-13-2014, 07:52 PM
Philip's Avatar
The X I mentioned is in the line that says model G56 then a dash with a number. The X means a number its normly a 6. I have seen one with a 4..
Of the G56's I have the one in my truck is a -6 model. A core G56 I have is a -6 and the other one is a -R. Those two have been checked by tooth count. The other good one I have is a -R. That one I haven't checked.
Running 60 MPH with the -R trans would put you right at 1500 to 1550 RPM. With a -6 trans you would be at 1650 with 235 tires.
If the price is right on that -R trans you still might think about it. 60 MPH in 5th is only 2K rpm. You wouldn't use OD with that .74 OD till 60 MPH or so. If you tow heavy that 5.9 1st might blow some. The deeper 6.8 gearing is nice rolling a heavy load off. Same with the deep reverse.
Old 10-13-2014, 08:40 PM
bobva's Avatar
Got fully understood
G56-6 or 4 = low geared
G56-R = high geared
Thank you
Old 10-13-2014, 10:02 PM
u2slow's Avatar
Honestly, I couldn't complain about any of those G56 ratios.... Ford's diesel ZF had 4.xx 1st and reverse. Low-range was a must for trailer jockeying.
Old 10-13-2014, 10:41 PM
bgilbert's Avatar
They both look better than the Getrag too.
Old 10-13-2014, 11:11 PM
There is a local guy who is selling one from a 08? I believe. But he says when he drained the oil it was metallic looking in colour. So had it replaced under warranty. Says it shifted fine, with no un-usual noises. Any ideas what might be wrong with it?
Old 10-14-2014, 10:05 AM
Philip's Avatar
Excessive end play in the gear train I bet. Loose end play from bearing wear and it lost its preload.
Old 10-14-2014, 10:14 AM
Usuable, re-buildable, or junk?
Quick Reply: G56 2wd into a W250
