how would this set up work
Old 04-06-2006, 09:56 AM
getblown5.9's Avatar
on a 98.5 truck
goerend full built auto and convertor
HRVP44 pump
edge drag comp
100hp injectors
the adkins lil 55 that i have...64 or 66/16...its laggy on my 6spd losing boost between shifts...how well would it run on an auto with the above lsited fueling mods?
i dont wanna sell it to someone who is gonna have just as many issues with it spooling as i have.
Old 04-06-2006, 02:41 PM
HOHN's Avatar
Sounds like a good combo provided the converter isn't too tight.
If the converter is too tight, you'll never get on top of that turbo and the lag will KILL you.
Something roughly equivalent to a DTT 89% is about where you want to be with a big single.
I've heard tales of fellas with race converters (DTT 93%) and big turbos that couldn't climb curbs in the truck-- not enough grunt!!
You'll also want the valve body set up for higher-rpm shifts. Otherwise you'll have a laggy start only to have the lag all over again when it shifts too soon.
JMO
Old 04-06-2006, 02:45 PM
seabee's Avatar
the good thing about goerand is he will work with you to get the converter right so it will light the turbo as you want it to . by playing with the internals of the converter
Old 04-06-2006, 02:52 PM
i had a fella that may have been interested but like myself, he is wanting the turbo in between stock and super sized
sooner or later ill find someone who wants this big boy for a mild pulling truck and ill be able to get my phat shaft or htb2
Old 04-06-2006, 06:18 PM
Willy91's Avatar
Sounds Like it'd be a good combo to me.
peobryant
04-14-2009 08:31 PM
dstad
02-13-2009 11:31 AM
rowley_141
07-20-2008 02:02 AM
nfsommer
25
10-09-2006 10:30 AM
Quick Reply: how would this set up work
