Wheel Cylinder Replacement
Old 12-08-2006, 03:11 PM
mitch@jc'sCTD's Avatar
Well i noticed my rear drivers side brake drum has fluid leaking out of it pretty good. So my first thought is the wheel cylinder is probably bad so i picked a new one up today, my quesion is what all needs to be done in order to replace the old with the new. Thanks mitch@jc
Old 12-08-2006, 04:39 PM
TIMMY22's Avatar
take it back and get the chevy 1 ton wheel cylinders. infidel has the part #'s.
cheaper and larger bore for more force on the brake shoes. might want to replace as a pair.
Old 12-08-2006, 05:45 PM
Tate's Avatar
Two bolts on the back, and a brakeline, and it should come right out. I was able to swap them without having to disassemble anything.
Old 12-08-2006, 06:15 PM
Fred Swanson's Avatar
Simple, easy and effective going to the GM wheel cylinders. I paid $11 each at NAPA for them when I did my brakes last month.
Old 12-08-2006, 07:09 PM
infidel's Avatar
Replace both cylinders with #37337 number good at any autoparts for about $13.
Your drums may be stuck on, easiest way to get them off is to put the rear end on stands, remove tires, put one lug nut back on loosely, start the truck put it in gear then slam on the brakes in forward and reverse.
You will only have to remove one spring to replace the cylinder. I always crack the brake line loose before removing the two bolts.
On a scale of one to five cylinder replacement is at an easy one.
Old 01-23-2007, 07:17 AM
rmjim's Avatar
Do the brake lines fit ok? i see that the dodge is std and the chev is metric??
Old 01-23-2007, 08:40 AM
DL1221's Avatar
Yes the #37337 Chevy wheel cylinders are a direct replacement, so they fit fine, the only difference is that they have a bigger bore than the Dodge wheel cylinders. I got mine at NAPA, but any parts store should be ably to cross reference that part number.
Just one thing to note, the first time I asked for this part number at my local parts store, they gave me Wagner wheel cylinders that looked different, they had the dust boot on the outside, instead of on the inside. Then I went to NAPA, and they gave me the correct ones which have the dust boot on the inside. I'm not sure why the Wagner wheel cylinders are different, or if they even fit, they are correct for a 1-ton Chevy truck.
Gen414
05-07-2009 11:08 AM
dennhop
05-03-2008 10:38 PM
cgmorgan06
11-15-2007 04:02 PM
Got Smoke?
05-24-2005 10:27 AM
Journier
11-22-2004 02:56 PM
Quick Reply: Wheel Cylinder Replacement
