Water Pump Failure
Old May 22, 2007 | 08:19 AM
3ton1/4's Avatar
Water Pump Failure
70,000 miles and water pump is leaking ! Is this common ? It should be covered under warranty right ?
Just wondering if this has happened to a few others.
Old May 22, 2007 | 09:03 AM
vzdude's Avatar
DTR's 'Go to Guy'
$100 deductible. Save some bucks and do it yourself. Bought a new ( not reman) from NAPA for 54 bucks. Took longer to drain and refill the cooland than to replace. 2 bolts and 1 o-ring after taking the belt loose. Good luck!
Old May 22, 2007 | 09:50 AM
3ton1/4's Avatar
read a post or two that says it should be covered completely since the truck is less than 5yrs old. haven't check my warranty info yet, but i will today. thanks. glad to know they aren't expensive and they are easy to install just in case.
Old May 23, 2007 | 11:26 PM
CLASSYCHASSIS's Avatar
water pump on 06 goes in tomorrow
Mine has 23000 on it and noticed something like rusty water from underneath. Then noticed my side of my afe intake that I just put on was slowly getting covered. You can tell that the fan is fling it around, some on valve cover, etc. So, I had to put the stock intake back on and they're gonna look at it tomorrow.
Old May 24, 2007 | 10:41 AM
3ton1/4's Avatar
Dealer said they couldn't get to mine until Wednesday ! Good news is, I pulled out the warranty book and it is covered.
Old May 24, 2007 | 04:03 PM
yep mines shot gettin replaced tomorrow.
Old May 25, 2007 | 09:54 PM
Bark's Avatar
The manuel talks about cleaning the water pump weep hole. Darned if I can see the thing to clean it. Does anybody do it?
IPDiesel
Jul 29, 2015 09:57 PM
dodgetrucker75
Mar 17, 2011 09:15 PM
Mexstan
Mar 5, 2011 07:43 PM
pfindly
15
Feb 8, 2010 10:00 AM
bhaugen
Nov 27, 2007 05:32 PM
