Water/Meth & Boost Question
Old Aug 25, 2007 | 09:20 AM
Mike T.'s Avatar
Lets say your capable of making 33psi boost on #2 and with W/M your up to
40psi +, what happens when wour wastegate is set @ 35psi, will it fall on it's face?
Old Aug 25, 2007 | 11:39 AM
BC847's Avatar
1st Generation Admin
I would say not.
Provided you're not capable of overpowering the wastegate, it should run just fine.
Either way, your wastegate is there to keep the turbo from over-spooling as well as keeping the available boost within the compressor's map.
Old Aug 25, 2007 | 12:23 PM
Mike T.'s Avatar
Thanks David..
Old Aug 25, 2007 | 09:02 PM
Micaiahfied's Avatar
mike T. my wastegate is set to 35psi... i can hit 35 psi without w/m and still only 35psi with watermeth. mine is a 12cm wg housing that i have drilled out the center divider to allow all 6 cylinders to waste.
dodgezilla04
Oct 18, 2008 03:44 AM
jdpiii
Jun 19, 2008 07:34 AM
65fury
Jul 1, 2007 10:43 PM
omaharam
Jun 16, 2006 01:47 PM
