valve chatter @ 2000RPM
Old 04-02-2007, 09:48 AM
REDNECK-WELDING's Avatar
hello, i have a 2000 dodge dually..it seems when iam around 1800-2000rpm theres lots of valve chatter..then ones its past it the noise goes away...i have a AFE air intake kit and im woundering if i am just hearing it more cause of that.. i had the valve lash done about 4000km ago.....is this somethiing to be worried about??
Old 04-02-2007, 10:52 AM
haloman's Avatar
I think I may have the same thing in my 01' it doesnt matter if I stay at the rpm or when i am going past that rpm it makes that chatter noise your talking about. Mine also does occansionally at 24-2500 rpms.
Old 04-02-2007, 12:24 PM
so it is something these motors do? or should i bring it in to get it looked at....
Old 04-05-2007, 10:16 AM
??????? no one else
Old 04-05-2007, 10:23 AM
Hillcountry's Avatar
I do not hear any chattering sound in the rpm range you describe. The sound of the engine is the same through the RPM range. Is this a new thing or has it always been that way...Now I will listen again to my truck, but I feel like there is no sound like you describe.
Did it do it before you adjusted the lash? When I adjusted mine, the constant valve clatter went away-the engine was much quieter and my mileage has improved 1mpg. Has your mileage dropped at all? Did you notice any difference in performance after the valve adjust? What specs did you bring the lash to?
Old 04-05-2007, 11:37 AM
i didnt do the adjusting myself.. a shop did it..it was louder before i did it..its is quieter now..i have only had the truck for about 15000km and it has done it the whole time..it is doing it right before it shifts.. the sound is louder than it is normal but it seems like the valves are just louder at this RPM not like ones out of adjustment....my chip was installed then the lift pump went so he didnt install it after...could the timing still be advanced?? or is it done through the computer??
Old 04-05-2007, 01:05 PM
Ahhhh...maybe you are hearing a timing issue...if that's the case it is probably out of my area of expertise...but I think the sound can be a result. Timing is done by the computer. If the chip modifies the timing maybe that is what you are hearing?
Old 04-08-2007, 07:38 PM
srt20's Avatar
sounds like a timing thing to me. My truck does it under light throttle. Then if you get back into it even just a little, the louder rattle goes away. Mine has done it stock, with Smarty, and now with Juice stacked. I think it just the ECM changing the timing on it.
Old 04-10-2007, 01:45 PM
great info..i will take out the chip and see if it helps or if the noise is still there...thanks
AggieJustin
18
01-12-2007 12:05 PM
bigman
08-07-2006 12:15 PM
Vanb
04-29-2006 05:58 PM
Dave04600
13
06-09-2004 08:50 PM
moparman2
07-04-2003 10:50 AM
Quick Reply: valve chatter @ 2000RPM
