Updating Quadzilla XZT+
Old 08-11-2007, 11:17 PM
lkuykendall's Avatar
I just received the new XZT+ for my 2001 and have been attempting to install updates from the Quadzialla website but must be doing something wrong. Windows is detecting the device and installing it as a USB to Serial Converter but is unable to start the device (Code 10). Device manager shows that the current driver installed for this device is from Quadzilla Inc, 1/3/2007 version 1.0.0.0.
I have attempted the update from a Windows XP machine and a Windows 2003 box with the same results. I have also used multiple USB cables to rule that out. I am sure there is something I am missing but I haven’t figured it out yet.
Old 08-12-2007, 12:38 AM
mudman78's Avatar
Originally Posted by wkuykend
Windows is detecting the device and installing it as a USB to Serial Converter.
That's what it did with mine. It says the device is working properly, but when I run one of the update programs, it says it can't detect the module and asks me to retry over and over.
Guess I'll have to call on Monday.
Old 08-12-2007, 08:08 AM
GFB
GFB's Avatar
I had the same problem and worked with them on it. Turned out all I had to do was hit update module and plug and unplug it a couple times until the flasher finally recognized the module. Worked fine since then but it was a pain the first time for some reason. I had the same code 10 error--which is only a time out error. The driver and eveything should still be installed just fine. I was told if you hit update module it looks for the module for 20 seconds until it times out. If you just try to retrieve info it only looks for 5 seconds or something like that.
Old 08-12-2007, 09:14 AM
firemandodge's Avatar
GFB is right. Try to run the program and wait until the update screen says "searching for module" and then plug the usb cable into the module. Sometimes when I run the update with the module already plugged in it wouldn't find it.
Old 08-12-2007, 12:13 PM
mudman78's Avatar
Worked like a charm guys. THANKS!!!
Old 08-12-2007, 12:26 PM
GFB/Firemondodge,
Thanks for the quick reply, it works perfect now!!
Len
sCreamin400
11-02-2008 01:46 PM
Batts
20
09-12-2005 07:39 PM
wdbates
38
08-10-2005 07:59 AM
MikeyB
04-20-2005 01:24 PM
onesourceoil
28
04-08-2005 08:13 PM
Quick Reply: Updating Quadzilla XZT+
