Underhood light switch?
Old Dec 11, 2007 | 11:33 PM
Hercules's Avatar
Anyone know where the switch is that activates the light in the engine compartment? I noticed when I hit a bump or drive on a rough road, I can see the light flicker from under the hood. I'd like to at least locate the switch to see what I have to do to adjust it or modify it if it's non-adjustable. It's for the truck in sig. Thanks!
Old Dec 12, 2007 | 12:11 AM
psmopar's Avatar
my 2001 3500 appears to be a mecury type switch. As the hood goes about 1/2 way down/up it cycles off/on. As far as I know these underhood lights mostly operate this way. There probably isn't a switch for this. You can tell by using meter on wires to light assembly and see if one is hot all the time. Then you will know....
Old Dec 12, 2007 | 12:14 AM
strokerace's Avatar
I noticed mine do that on my way home after I bought it. I pulled out my bulb and just carry a flashlight if I need to look under the hood. The little light isnt all that bright anyway.
Old Dec 12, 2007 | 07:35 AM
Busboy's Avatar
I just leave mine unplugged, if I need it I just plug it in temporarily.
Old Dec 12, 2007 | 10:05 PM
Hercules's Avatar
Thanks for the help. I was thinking about pulling the bulb and putting it in the glove box just in case I need it...or just live with it. Thanks again!
Old Dec 13, 2007 | 08:08 AM
ironbutt's Avatar
The switch is a intregle part of the light housing it's self. So if you feel better with it off, then unplug it till you need it.
Old Dec 13, 2007 | 10:43 AM
1-2-3's Avatar
Just a plain ole guy
You can add a simple inlie switch. As said above, one wire is always hot. Snip it, add a switch. Then you don't have to dig out the bulb when you need it, just flip the switch.
While your at it, add another light so you can actually see something with the underhood light on at night.
Old Dec 13, 2007 | 06:46 PM
WestTN's Avatar
I'm wondering how the heck you see that light while driving. My hood covers mine.
Old Dec 15, 2007 | 12:15 AM
Hercules's Avatar
I can see it flash through a space between the hood and cowling while driving at night. It probably helps that the foam weather seal has disappeared allowing for a better view. The first time it happened I thought something was sparking under the hood until I realized what it was.
Clane
Mar 28, 2009 01:44 PM
marka
Mar 23, 2005 10:51 AM
Jan 25, 2003 05:45 AM
