ULSD and Plugged filters
Old 12-20-2006, 02:32 PM
ofcmarc's Avatar
Anyone out there getting plugged fuel filters more often now that the switch to ULSD has happened. I'm about to have to put a second filter on in only 3 weeks.
On another thread there was a post stating that ULSD had some solvent properties and would clean out your tank/lines. I've heard of this with BIO but not ULSD but maybe....
Any thoughts/experience? I'm asking the first genners cause we're the ones with the older trucks and a greater chance of crud in the tanks/lines.
Old 12-20-2006, 02:47 PM
pred's Avatar
No issues here, I have also for the last 16K miles have been running 10%-70% WVO in the tank with the diesel.
Peter.
Old 12-20-2006, 03:26 PM
willieboy's Avatar
I'll let you know. I just put the first tank of the ULSD in the truck yesterday. Of course with the way I have driven it lately, it will take a month before I fill it again...
Old 12-20-2006, 03:47 PM
Been running it since mid-October and the fuel pressure is still stable.
Old 12-20-2006, 08:53 PM
lowwag64's Avatar
hey wanna,do you have a fuel pressure gauge in your cab or under your hood? any pics of the set-up? what is a good (common) pressure?
wanna,I just read your post in another question.Thanks
Old 12-21-2006, 03:53 PM
The pressure gauge is in the cab. The current setup is a little different than most would run due to the secondary fuel system.
Old 12-22-2006, 03:32 AM
Diesel Junkie's Avatar
My truck has been uncharacteristically reliable since the cutover to ULSD.
Old 12-22-2006, 05:19 PM
stillsmokin's Avatar
Semi on topic, I have read howes lubricator has a higher sulfur concentration than power service. The new bottles have warning labels for those new low-fat diesel owners. I been running it 1 oz per 2 gallon since the low-fat diesel was forced on me. My fuel pressure guage has been wierd since the switch, my filter was new in august or 4000 miles back.
I had to mod the fuel sending unit this summer before the county fair pulls. The tank on mine was spotless inside after 238,000 miles of use. It had never been out. I suppose what you find in the tank depends on where you buy the fuel, and where it was before that.
Old 12-22-2006, 08:18 PM
Boatnik's Avatar
I'm with Wanna on this one. I've been running ULSD for over a month now and I cannot relate any problems. My fuel pressure on the stock pump is 5psi at idle and about 3psi WOT. The filter was changed in the spring........I think
Old 12-23-2006, 08:43 AM
Ace
Ace's Avatar
ULSD was in the pipelines in many places around the end of summer. There may have been some time lag between deliveries and updating the pump documentation. IIRC, the mandatory cutover date was 1 October.
Old 12-24-2006, 07:54 PM
Boatnik's Avatar
If my memories serve me correctly, that sounds about right. That is when the warning sign on the pump changed to "This fuel is approved for all 2007 and earlier diesels engines". Wish they could bump up the energy and mileage or at least lower the price. I feel like I being ripped off every time I fill up .
klx650a2
15
02-15-2008 01:27 PM
Red3quarter
15
11-01-2007 07:55 AM
fitzydog
10-12-2007 10:23 AM
kelley15
08-20-2007 04:52 PM
mr T
02-24-2007 06:42 AM
Quick Reply: ULSD and Plugged filters
