Turbo leaking oil.
Old 08-20-2006, 12:52 AM
DL1221's Avatar
Turbo leaking oil.
Today when I took the air box and tube out to clean them I noticed that the veins on my turbo were covered in oil, this is not normal is it? I assume there is a seal in there that has failed, are there any turbo rebuild kits that I can buy? Thanks for any help. Oh, there is also in/out play on the turbo shaft, is this normal?
Old 08-20-2006, 06:38 AM
plow's Avatar
NO, forward and aft play is no good. http://www.htturbo.com/7.html
Old 08-20-2006, 08:02 AM
Registered
blackdiesel's Avatar
which truck? might be easier to change it. there's alot of guy that have upgraded turbos, and you could pick up a hx priced right
Old 08-20-2006, 11:00 AM
DL1221's Avatar
Checked both trucks, and both turbos have forward and aft play -- you can pull the shaft in and out about 1/8 of an inch, and slightly more on the 96. Can they be rebuilt, or is it better to replace them? Thanks. (I know this is the 12-valve forum, but should I get an HX to replace the HY on the 01?)
Old 08-21-2006, 01:16 PM
plow's Avatar
Yes they can be rebuilt or replaced its whatever you want to do or how much money your willing to spend.
lilsuzuki4x4
09-01-2011 01:50 AM
ohyeahfriday
10-09-2007 09:38 PM
zukgod1
10-31-2006 01:45 PM
Tommy93w350
06-20-2005 04:51 PM
running4bhs
05-17-2005 07:07 PM
Quick Reply: Turbo leaking oil.
