Turbo or Injectors
Old Mar 23, 2006 | 09:55 PM
puffmagicdiesel's Avatar
Turbo or Injectors
Torn between getting a new turbo or edms, what do u guys think im worried over boosting if i get the edms already at 28#s at wot, and i was thinking HX40or is there something else u moght sugest, or formula one injectors what do u guys think
Old Mar 23, 2006 | 10:20 PM
edwinsmith's Avatar
From what I gather you need more boost before you need more fuel. Otherwise your EGT's go to high.
Edwin
Old Mar 23, 2006 | 11:08 PM
Bushy's Avatar
Patron Saint of 1st gens
I agree, the air supply needs to be improved and not just boost pressure's but efficient boost is the key.
Look at all the options available for turbo's and, keep in mind that you'll also need to be planning for the future too....we all know it's really hard to stop tweaking and tinkering so your turbo choice should be made with your "ultimate or final" goal in mind or else you'll be doing this over again...
pb...
edit: I do not recommend the HX40 turbo. It is not as durable as the hybrids out there and, it WILL be pushed too hard eventually to stay in working shape.
Old Mar 23, 2006 | 11:59 PM
whats a good strong hybrid my goal is around 300+ poinies
Old Mar 24, 2006 | 05:35 AM
bgilbert's Avatar
HTB2 62-14, 64-14 from www.htturbo.com. You'll need to fab up a 4" downpipe. Much more durable than a hx40. Then a good set of EDM's.
Old Mar 24, 2006 | 11:23 AM
what about upgrading stock turbo with there stageIV compressor and 14cm wastegated housing ive seen a few of those in people sigs
Old Mar 24, 2006 | 05:54 PM
bgilbert's Avatar
JMO, I say save your money on those items and go straight to the htb2 line. You won't be spending twice in the long run.
Old Mar 24, 2006 | 06:42 PM
It all depends on how far you're gonna go. I would have been better off buying a bigger single. Somebody with lower goals would be fine with a hybrid, at a much lower cost. I wouldn't spend the money on a new 14 cm wastegated housing. If a 12 cm is too small and a 16 cm is causing overboosting, then you need a bigger turbo anyway.
Ada381
Feb 10, 2008 07:58 AM
KRB
May 20, 2007 06:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
