Turbo drain plug?
Old 01-07-2007, 09:28 PM
BlueDually's Avatar
Turbo drain plug?
How does it come out?
Im trying to install a sps 62/14, and cant reach drain bolts when its in position. Ive read that its easier to bolt the drain to the turbo first, then lower it back in, but I cant get the !!!!ing drain off the block. Whats the trick?
Old 01-07-2007, 09:39 PM
dodgezilla04's Avatar
the drain pipe is held in place with an o ring. just very gently wiggle and pull, it will come out suddenly enough to bash your knuckles. did you pull your wheel well liner out? makes it much easier.
install the drain on the turbo before you put the turbo in. i went through the same thing when i installed my 62/14
Old 01-07-2007, 10:03 PM
BlueDually's Avatar
I can get it to move/rotate, but I was pulling on it as hard as possible. Im not quite the size of Hogan, but still
Yes I got the liner out, did most of the unbolting from the wheel well,
If the wastegate was positioned a little different, that turbo would fall in to place, wouldnt have to unbolt the manifold at all, and still be able to reach the drain line bolts
Old 01-07-2007, 11:53 PM
BlueDually's Avatar
I just read there is a 1 piece and a 2 piece drain,
I have a 1 piece, if anybody else has any comments.
Old 01-08-2007, 04:37 PM
Muted User
Jfaulkner's Avatar
That's it just pull. It's in there pretty good so if it's not coming keep pulling.
P.S. go ahead and punch the frame rail your going to anyway when it finally comes out so you better get the swearing out of the way.
Old 01-08-2007, 04:39 PM
mine was a 1 piece, pull man pull
Old 01-08-2007, 04:47 PM
Dodgezilla's Avatar
Mine too and it came out pretty darned easy....
Keep pulling....
Old 01-08-2007, 06:10 PM
wap
wap's Avatar
Jfaulkner, that just made me laugh out loud
Old 01-08-2007, 07:34 PM
BlueDually's Avatar
Got her, I kind of pushed in, twisted and pulled at the same time
But before that, when i tried to bolt up the drain in place, I broke the flange on the drain line,
Picking up a new drain tube in the am at the dealer for $200, this turbo install just keeps on getting better
Old 01-08-2007, 09:08 PM
Muted User
Jfaulkner's Avatar
$200.00???? Um.....mine was less than $50 from the dealer. You can get them online (part #0428) for about the same price. You had better make sure they're talking about the same piece.
Old 01-08-2007, 09:21 PM
Smokeman's Avatar
Oh man thats expensive...phone cummins western canada with your engine serial number and price one out.
Old 01-09-2007, 12:51 AM
BlueDually's Avatar
I thought $50 at the most. But for some reason, its shown as a 3 piece part it the mopar parts catolog, and somehow adds up to $200 Canadian.
Did that, called local International/Cummins dealer, they said its cheap but unable to get through Cummins Western Canada. That doesnt even make sense, how the can have a price and not be able to get the part, makes me
klx650a2
01-10-2008 12:08 AM
wooff
05-01-2003 11:22 AM
Dodgezilla
11-24-2002 07:31 AM
cpermd
10-28-2002 02:19 PM
Quick Reply: Turbo drain plug?
