TST with Diablo Predator
Old 04-11-2007, 09:17 AM
powerstrokin03's Avatar
Has anyone done a stack with TST and the Diablo Predator? If so how do you like it, is timing an issue?
Old 04-11-2007, 09:22 AM
973604x4's Avatar
i've had the same thought.....
i don't think there would be a timing issue since diablo has an "extreme stacker" tune....and the TST has adjustable timing.
Old 04-11-2007, 09:44 AM
Phil that's if your TST does timing which unfortunately mine doesn't
Old 04-11-2007, 11:03 AM
sterling's Avatar
stacking tst and predator
I,m using that stack for a while now.
I run the predator on extreme ,and the tst on 2x3 or 2x2, and railpress on 1 and timing on 3 .
Running the timing on 6 will rattle a bit if the engine is cold ,after 5 minets its gone.
Smokes a lot ,egt,s out of control.
This is a nice stack,good power.
I,m going to install the BD twins next week ,so I have to find new settings to make it all work well.
I will let you guys know how the twins perform.
sterling
Old 04-11-2007, 11:06 AM
When you say out of control how high are we talking. With my SMARTY and TST my egt gauge hits 1600 about 3 seconds after i floor it.
Old 04-11-2007, 11:17 AM
trik396's Avatar
The stacker tune only removes pressure, not timing...
Old 04-11-2007, 11:29 AM
well then until i get a different TST im stuck with SMARTY with no timing
Old 04-11-2007, 11:38 AM
973604x4's Avatar
sterling
stock turbo?
oh ok...whats the tune Johan sent Omaharam for the Juice Stack? it had less timing.
Old 04-11-2007, 11:54 AM
trik396's Avatar
Don't know... he probably requested a specific tune... I requested a 200hp tune with no pressure and Johan emailed it to me but I have not loaded it yet.
Old 04-11-2007, 11:58 AM
973604x4's Avatar
that sounds fun. be sure to post how you like it.
Old 04-11-2007, 04:21 PM
sterling's Avatar
EGT,s are 1500+ also after a few seconds,so I don,t do that too long.
I,m still using the stock turbo for now.
sterling
mx684
04-07-2008 03:53 PM
Mark Craig
103
06-02-2006 02:24 PM
floridagc
18
05-30-2006 07:57 PM
kelley15
05-18-2006 09:21 PM
Quick Reply: TST with Diablo Predator
