TST and PPE?
Old Feb 14, 2006 | 01:56 PM
tweeter's Avatar
TST and PPE?
Anyone tried stacking a TST w/twins with the PPE 215 Hp downloader?
Old Feb 14, 2006 | 02:31 PM
Jeff K's Avatar
that's what Piers is using in his high HP truck. Seems like it works pretty good
Old Feb 14, 2006 | 02:40 PM
WUnderwood's Avatar
he put down 680hp, correct???
Old Feb 14, 2006 | 09:30 PM
tweeter's Avatar
GIDDY-UP, sounds like a better idea already.......think head studs should be on the list too...........(58 psi on a regular basis already.......) Jeff K, how's it goin neighbour? We really need to get together for a beer soon. PM me when you have time.
Old Feb 14, 2006 | 09:35 PM
abc4yew's Avatar
Tweeter, I thought the PPE HOT was only good on the 04.5. ks
Old Feb 14, 2006 | 09:58 PM
Don M's Avatar
DTR Advertiser
I had a friend dyno his 03 with a PPE. It is not the HOT version. It made 40 more HP over the TST. I put my small pressure box on and picked up another 20.
I think the HOT PPE is only for the 04.5 and up trucks.
Old Feb 15, 2006 | 08:48 AM
abc4yew's Avatar
DonM, Do you mean PPE stacked with TST and your box? ks
Old Feb 15, 2006 | 10:48 AM
Don M's Avatar
DTR Advertiser
Yes, he had the TST stacked to the PPE. He gained 40 over the TST alone. Then stacked our small pressure box and picked up another 20.
Old Feb 15, 2006 | 05:57 PM
abc4yew's Avatar
Hmmmmm, that sounds nice.....an expensive 40hp though but if your at max....what was the TST set at. I thought with the proper injectors and timing (cam), we (the 03 and 04 guys) could run the TST to 9x9 and get increases all the way. 7x7 or 8x5 are my top settings before heat stroke (soak), but that is the stock turbo and lack or cool air volume. With waterwaterwatermethanol I could run 9x9, but the turbo would hate me. ks
Old Feb 15, 2006 | 07:13 PM
tweeter's Avatar
The PPE I was looking at is the Xcelerator, rated at 215 HP and 350 FT/LBS. I called them direct and they don't make a HOT version for the 03/04. Figure it should work better than my Edge EZ stack. My Stage 3 water meth kit should be here next week, hoping this combo should get me close to my goal of 700 RWHP. If not, I may try NOS.............
chromestack
Dec 11, 2008 10:09 PM
Caterpillartim
Jun 23, 2008 03:59 PM
smoky beast
28
Oct 13, 2006 01:15 PM
smoky beast
Sep 10, 2006 11:18 AM
