Truck Surging problem
Old 08-11-2008, 06:33 PM
cvcook's Avatar
Took my Triple dog out of my truck,(stock program) and now at wot it surges and my RP gauge jumps back and forth from about 17-23k, any idea why this happens?
Old 08-11-2008, 06:37 PM
rip 112's Avatar
FCA sticking maybe?
Old 08-12-2008, 04:31 PM
cvcook's Avatar
So, what excactly is a FCA?
Old 08-12-2008, 06:58 PM
rip 112's Avatar
Fuel Control Actuator. It is located on the CP3 and regulates the amount of fuel coming in and being dispersed in everystroke. If it is sticking it will cause surging, fluctuating RPs and in some cases rough idle.
Old 08-13-2008, 07:32 AM
cvcook's Avatar
OK, Thanks Rip
Old 08-13-2008, 11:39 AM
XLR8R's Avatar
Did you cap the rail by any chance?
Old 08-13-2008, 05:00 PM
cvcook's Avatar
Capping the rail, how's that done?
Old 08-13-2008, 08:13 PM
chrleb1's Avatar
Take the overflow banjo out, tap the inside of the banjo for 1/8th pipe and then put a plug in it. Make sure you get the plug flush with the bottom of the banjo bolt. If you can't, grind it flush. After you clean it very well, re-install it into the overflow valve.
Old 08-13-2008, 08:16 PM
XLR8R's Avatar
... did you remove the Pressure Release Valve's banjo bolt from the high-pressure common rail and replace it with a solid bolt or one of the aftermarket rail caps.
Big Smoky
09-09-2008 01:37 PM
HuskerPower
01-30-2008 12:15 PM
JD730
06-04-2006 07:27 AM
Random_Sample
02-07-2005 10:35 PM
stonewalldiesel
03-19-2004 01:14 PM
Quick Reply: Truck Surging problem
