Transmission Temps.??????
Old Dec 25, 2006 | 01:00 PM
boaterman's Avatar
Looking for the best deep aluminum transmission pan. I need to keep the temps down while towing my 5th wheel during the summer in Texas.
Has anyone used the larger pans? How mush of a reduction in temp?
04 3500 srw/sb towing machine.........
Old Dec 25, 2006 | 05:22 PM
bluebull's Avatar
Have never used a larger pan but you want the double deep pan. The newer pans are already deeper than the earlier ones. I think it was 98 or 99 that DC increased the pan size.
click on this link www.genosgarage.com don't know if there the lowest priced but good people.
Old Dec 26, 2006 | 12:34 AM
TexasCTD's Avatar
http://www.genosgarage.com/prodinfo....=MH-727DD-9803
I have one of these, but honestly I can't tell you how much it cools the temps because I didn't have the transmission temp gauge until I installed it. I have towed some in VERY hot Texas weather and have never seen over about 190-200 degrees that I can recall. Hope that helps.
This DD pan holds 4 quarts over the stock pan.
Old Dec 26, 2006 | 12:52 AM
Marine's Avatar
Veteran: Marine Corp
You might want to look at a bigger and more efficient cooler as well.
Old Dec 26, 2006 | 10:01 AM
Patriot2500's Avatar
I have the Mag-Hytec pan and my temps are around 150* constant. In the summer, it hangs around 160* or so.
Old Dec 26, 2006 | 10:36 AM
boaterman's Avatar
I just ordered the Mag-Hytec pan..............
Next on the list is the 65hp Quad tow box. But first, I need more info like that I received on the pan..
kart77
Jan 3, 2010 02:05 PM
yousoobad
Jun 29, 2009 07:11 AM
SMKHZRD
May 12, 2009 07:37 PM
nitrousn
Jan 12, 2005 11:29 AM
anestech*
Nov 7, 2004 12:18 PM
