Transmission Swap
Old Sep 13, 2004 | 01:08 PM
Alexd's Avatar
Transmission Swap
I have a couple more questions about swapping transmissions in my 91.
If I wanted to update the tranny from the A727 to a A518 or A618, which one would you guys do? Am I correct in thinking the A518 in hydraulic operated, but has no lock up, and the A618 is electronic operated but has lock up?
Or should I just get my tranny rebuilt stoutly and buy an aftermarket overdrive. I was intending to swap to a NV4500, but now I am getting nervous about the conversion from auto to stick, I cant seem to find the pedals.
What would you guys do? I have about 4k to get all this done with and each day my current A727 is getting worse.
Old Sep 13, 2004 | 02:43 PM
ares's Avatar
pedals arnt your problem, gearing will be. if you pop a 4500 in with 3.07s you maybe able to set a new land speed record. you could get pedals out of a bone yard. then buy a high impact or quad 4x4 conversion kit if you have a W youd need a different transfer case or rebuild it. if you went to a A* tranny youd probably have to do everything plus resize your drivelines and new tranny mounts.
Ill be using mine till it falls out or i can get all the parts to swap.
Old Sep 13, 2004 | 02:47 PM
Alexd's Avatar
I think I have the NP205 TC, why would I need to rebuild it? I would need a flex plate too I think.
Old Sep 13, 2004 | 02:58 PM
ares's Avatar
the auto has fewer splines than the manual. think the 727 has 23 splines and the getrag and 4500 have 29.
heres some links:
http://www.high-impact.net/transmiss...88-03_auto.htm
http://www.quad4x4.com/NV4500HD%20Conversions.htm
also do some searching on the board there have been several swaps documented and photographed on here and tdr.
Old Sep 13, 2004 | 03:17 PM
Alexd's Avatar
I see your point, I am still undecided. I want the stick but something is steering me away as far as getting all the prices, afraid of running over budget, you know. I thought I looked for those type of threads and didnt find anything else, about tranny swaps. If you get time think you could paste the links so I could see the pics.
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
stone
Feb 11, 2005 11:50 PM
ceyl
Jan 21, 2004 09:08 AM
