transmission metal in pan.
Old 08-05-2011, 02:22 PM
johnny08's Avatar
Ok i was running good shifting good ... and when i got to my destination... ATF was running out under the truck.
My cooler line had been spliced with a cheap looking hose ... And this hose split.... So I got a ride for a new hose and added fluid 3 Quarts... felt a slight slip and added two more quarts... slowly drove a few miles and added three more quarts of fluid...
After all this my shifting is real weak... And i drop the pan found some metal shavings... looks like about a half a teaspoon worth... And its not magnetic.
What could this be???
is my converter bad???
Old 08-05-2011, 08:14 PM
jesussaves's Avatar
converter clutches
Old 08-05-2011, 09:44 PM
johnny08's Avatar
Should I replace the converter?? or will it be OK? I was just gonna do a shift kit and adjust the bands.
Old 08-05-2011, 10:25 PM
366 Spring Chicken
Richie O's Avatar
Originally Posted by jesussaves
converter clutches
We don't have clutches in our conv's.
Old 08-05-2011, 10:30 PM
1st Generation Admin
BC847's Avatar
Assuming you have the stock/OEM 727 or A518 transmission (don't know what year 1st gen you have), your transmission runs a NON lock-up torque converter. As such, it has NO clutch in the converter.
Are you positive the material is metal? The clutch-packs associated with each gear use steel discs between the clutch discs. The only non-magnetic metal in the trans is aluminum, that being the valve-body and the transmission case.
DOH! Rich done treed me!
Old 08-06-2011, 11:40 AM
kensmachine's Avatar
you cant pull the pan of a 727, 518, 618, 904,500, with out finding some metal in the pan. transmission shop trade secret look your trany is on the way out time for a rebiuld. the aluminum comes from the plants and converters stator Ken
Old 08-06-2011, 08:52 PM
The_Head's Avatar
How much is considered "normal wear"?
I remember pulling my pan last year and there was some in the pan. I figured it was from the tranny breaking in. I dunno.
Old 08-07-2011, 04:31 AM
jughead's Avatar
i have never pulled the pan on a torgue-flite that didnt have a small pile of metal in it. dont worry about it unless you see a thin layer over most of the pan. in 40 years i have pulled a fair share of those pans.
mattmanj2001
08-19-2010 08:18 PM
archer39
02-17-2009 09:58 PM
EverydayDiesel
11-11-2007 09:33 AM
3500CTD
02-10-2007 12:48 PM
Ghost Ram
01-23-2007 02:08 AM
Quick Reply: transmission metal in pan.
