Transfer Case Question
Old 07-22-2007, 06:15 PM
BPM
BPM's Avatar
Location: Shreveport LA for 10 days at a time, Groveton TX the rest
I was changing my oil today on the 03, when I noticed that there had been fluid coming out of the transfer case. It was mainly concentrated around a 7/8" plug at the bottom, so I put a wrench to it to tighten it up. When I did that it sheared the plug off and a spring and what looks like a bullet, for lack of a better word, dropped out. I have been to all the auto parts stores around here and no luck. Is this the normal drain plug that I broke? If not what is it?
Old 07-22-2007, 06:35 PM
DTR's 'Go to Guy'
vzdude's Avatar
That is the detent and spring. Dealer only part I would assume.
20 SCREW 4886473AA
21 SEAL 4338956
22 SPRING 5019538AA
23 PLUNGER 53008217
Old 07-22-2007, 06:40 PM
BPM
BPM's Avatar
Thanks for the quick reply. That diagram really helps as well.
So I'm guessing just get the part and put it in and refill with gear fluid and I should be good to go?
Old 07-22-2007, 07:09 PM
danc46's Avatar
The transfer case does not take "gear fluid". The transfer case uses ATF IV fluid.
wyododge
08-18-2011 07:48 AM
tjohnson
05-27-2005 01:06 AM
FRANKV569
12-31-2004 01:05 PM
Pike
10-03-2004 09:30 AM
Quick Reply: Transfer Case Question
