Transfer Case Question
Old Jul 22, 2007 | 06:15 PM
BPM's Avatar
BPM
From: Shreveport LA for 10 days at a time, Groveton TX the rest
I was changing my oil today on the 03, when I noticed that there had been fluid coming out of the transfer case. It was mainly concentrated around a 7/8" plug at the bottom, so I put a wrench to it to tighten it up. When I did that it sheared the plug off and a spring and what looks like a bullet, for lack of a better word, dropped out. I have been to all the auto parts stores around here and no luck. Is this the normal drain plug that I broke? If not what is it?
Old Jul 22, 2007 | 06:35 PM
vzdude's Avatar
DTR's 'Go to Guy'
That is the detent and spring. Dealer only part I would assume.
20 SCREW 4886473AA
21 SEAL 4338956
22 SPRING 5019538AA
23 PLUNGER 53008217
Old Jul 22, 2007 | 06:40 PM
BPM's Avatar
BPM
Thanks for the quick reply. That diagram really helps as well.
So I'm guessing just get the part and put it in and refill with gear fluid and I should be good to go?
Old Jul 22, 2007 | 07:09 PM
danc46's Avatar
The transfer case does not take "gear fluid". The transfer case uses ATF IV fluid.
wyododge
Aug 18, 2011 07:48 AM
tjohnson
May 27, 2005 01:06 AM
FRANKV569
Dec 31, 2004 01:05 PM
Pike
Oct 3, 2004 09:30 AM
