Trans temp gauge retrofit?
Old 01-20-2010, 09:45 AM
93wuntun's Avatar
the mean-spirited, mechanically-disadvantaged previous owner was kind enough to clip the sender wires on the auxillary trans cooler. I don't know what kind of auxiliary cooler it is, theres just 2 sad little wires there stickin' out of the sender.
Can I use any type of electronic gauge? Or are senders and gauges 'matched'...?
Thanks in advance.
Robert
Old 01-20-2010, 10:04 AM
apwatson50's Avatar
It is probably a switch, not a sender, to turn the fan on at a certain temp.
Old 01-20-2010, 11:20 AM
93wuntun's Avatar
thanks for the reply, you may be right, there is currently a manual toggle switch to turn on the trans cooling fan, but theres also 4 little holes in the top dashboard where someone removed what I assumed to be the trans temp gauge mount... (yes I know what happens when I assume)
I'll be doing a little research on external trans coolers now.
Old 01-20-2010, 01:53 PM
dieselJon's Avatar
The aux trans cooler turned on by a switch on the hot side exit point on the tranny. If the sender detected too hot of temps, it would turn the fan on.
1985cucv
02-18-2010 02:03 PM
mar67655
03-21-2009 05:35 AM
Richpwb
08-15-2008 08:01 PM
djgaston
10-30-2005 03:18 PM
live wire
07-21-2003 07:26 AM
Quick Reply: Trans temp gauge retrofit?
