Trans gauge on a 6 speed
Old 12-30-2004, 07:07 PM
cliffs03hd's Avatar
Where should I plumb this in at. Thanks guys
Old 12-30-2004, 07:12 PM
OOPS's Avatar
Why do you need one on a manual tranny????
Old 12-30-2004, 07:16 PM
cliffs03hd's Avatar
It came in the set. If I cant use it I can send it back in and trade it up for a differant guage. any ideas. I have the ISSPRO 100 psi boost, 30 psi fuel, Pyro, and trans temp. Also is it okay to plumb the egt gauge in to the TST probe as well.
Old 12-30-2004, 08:24 PM
Mike_Boutet's Avatar
I'd be more tempted to put a temp gauge in the rear diff rather than the tranny,especially if towing heavy.
Old 12-30-2004, 08:54 PM
Fred Swanson's Avatar
Do both, and put a switch on it. The tranny gets hotter than you think. Put a bung on one of the PTO cover plates. No, the gauge and the TST need their own probe.
Old 12-31-2004, 02:21 PM
snapp919's Avatar
I'm in the same circumstance also, got the guages in a set. Would like to know the best place to install the sender on the 6 speed for anybody that might know.
Old 01-01-2005, 03:48 AM
DSLRammin's Avatar
ISSPRO 100 psi boost Trade in that temp sensor for a heart rate monitor gauge I'd like to see that gauge pinned out!!
Old 01-04-2005, 10:21 AM
grizzly660fan's Avatar
I had a trans temp gauge put on my manual six speed. that tranny does get hot when towing. if not towing, its not worth having a guage on it. never seen it get hot enough to worry when not towing.
I had my gauges installed at a shop, I will look under mine to see where they mounted the probe and get back to you.
I am looking for a manual trans cooler. anyone know where to get one of those? I have seen the "fast coolers" they only seem to help a little. I can wind up my trans temp to 220f or 230f if not careful.
Old 01-04-2005, 04:18 PM
cliffs03hd's Avatar
thanks for the help guys,
1985cucv
02-18-2010 02:03 PM
Suneview_Farm
12-25-2007 10:18 PM
goodeyesniper75
05-16-2007 01:58 PM
djgaston
10-30-2005 03:18 PM
live wire
07-21-2003 07:26 AM
Quick Reply: Trans gauge on a 6 speed
