Tow limits
Old 06-05-2008, 11:45 PM
billyfish's Avatar
Tow limits
I have a 2007 2500 5.9 4x4 MEGA 379 rear end auto trans I thought when I bought it from the dealer they said I could tow 15000 fith wheel the dodge web site says 12500 max Cant you tow more with a fith wheel What is my max and were can I get the info
Old 06-06-2008, 12:07 AM
Spooler's Avatar
Rear axle weight is going to be the biggest issue you have due to the weight your tires can support. Truck with 3.73 rearend GVWR is 21,000lbs and with 4.10's is 23,000 lbs. You really needed a 3500 dually with 4.10's to carry that weight. Yes, your truck will pull it but you may have some issues. Your rear tires load rating in a single configuration is around 3100 lbs each. So they will limit you to 6,200 lbs. on the rear axle. If you have a warranty issue and they find out how much weight you tow you may have a problem. I know of one on this board that has had that issue. They ended up voiding his warranty.
Old 06-06-2008, 12:13 AM
billyfish's Avatar
So your saying I can only haul 6000 lb
Old 06-06-2008, 12:24 AM
Dieselnick's Avatar
You can't have over 6200 LBS on your rear axle or you will overload your tires. You should hit a scale with your 5er hooked up and fully loaded and see where you are. The 12.5 rated limit sounds about right, but as long as you don't have over 6200 on the rear you'll have no problems towing your 15K 5er.
Nick
Old 06-06-2008, 12:30 AM
With age comes the cage
Colo_River_Ram's Avatar
http://www-5.dodge.com/vehsuite/TowingGuide.jsp
Old 06-08-2008, 10:22 AM
stickler's Avatar
Being ABLE to tow it and being LEGALLY able to tow it are two totally different things.
Old 06-08-2008, 11:13 AM
KWKING's Avatar
Dodge makes a booklet ,you should be able to get it from from the dealer,mine is" 2006 Truck Specifications Guide "it gives you box size,seat dimensions and towing and weight info for all configurations of Durango and Ram trucks,mostly in chart form ,22 pages,I am sure yours would be the same as an 06 since you have a 5.9l/48re combo.Your max. trailer wt.= 12550# and max. payload=1680#......13550#/2590# for a 3500 1 ton.Those are Mega cab specs. auto only SRW with the stock E rated tires and 373 rear end.
Old 06-08-2008, 10:20 PM
AH64ID's Avatar
Originally Posted by Colo_River_Ram
With 3.73 Axle Ratio Axle Ratio [i] You Can Tow 12400 lbs
Gross Vehicle Weight Rating (GVWR) [i] = 9000 lbs
Payload [i] = 1557 lbs
Curb Weight [i] = 7443 lbs
GAWR Front/Rear [i] = 5200 lbs/6010 lbs
Gross Combination Weight Rating (GCWR) [i] = 20000 lbs
But to get your best answer go to the scales and subtract your loaded weight from 20000 lbs, thats really your tow rating. Also make sure you don't exceed the tire ratings on the rear axle.
FYI, the same truck in a 3500 SRW is rated for 13,550 and the only difference is the 3500 SRW has overloads, the rest of the truck, including the main leafs, is the same... So thats a closer number to what the truck can handle according to the mfgr... I suggest airbags to help keep the truck level.
Shipskym
02-05-2014 11:27 AM
bigfoot
03-18-2003 06:28 PM
furious70
03-13-2003 06:26 PM
TON4FUN
25
02-14-2003 03:44 PM
bullfrogjim
10-17-2002 10:50 PM
Quick Reply: Tow limits
