throttle shaft indexing?
Old Aug 16, 2008 | 12:40 AM
Alwaysworking's Avatar
alwaysonDTR
i was thinking what have you guys done to achive full fuel after reindexing your throttle shaft? when you turn up the pump enough to need it.
since you have to lenth'in the throttle linkage to get it to idle but that then doesn't allow full throttle travel because the linkage is too long
now i fixed mine today so i know what i did but how did you do it?
and on my truck fixing this issue got me about 500 to 1,000 rpm more than what i have been driveing it at
i will post pics later, since its dark outside right now
Old Aug 16, 2008 | 03:36 AM
I always switch the linkage and the return spring holes on the throttle lever.
Old Aug 17, 2008 | 12:59 PM
alwaysonDTR
i decided last night since the road was clear and i hadn't had a chance to see what it would do since i fixed the throttle travle, to hammer it. it pulled hard all the way up to 3,400 rpm maybe 3,500. wow what a difference that little bit can make
Old Aug 24, 2008 | 11:26 PM
alwaysonDTR
that is what i did to get full traval but switching the spring and linkage might have been enough?
and i had a steel ball like the throttle linkage uses left over from a gas strut kit for like a tool box
Bg enemy
Dec 1, 2012 08:47 PM
TrkEnvy
Oct 27, 2012 06:35 PM
89f150
Oct 23, 2008 07:41 PM
bradshaw106
Sep 26, 2008 05:31 PM
G1625S
Mar 7, 2006 06:17 PM
