thinking about putting my Autometers in, Pyro ?
Old 10-09-2007, 12:52 PM
Dusty Ratcliff's Avatar
well, I've had a set of autometer gauges (boost/pyro) since I bought my truck & am just now getting around to installing them, my ? is how many of you drilled & tapped your manifold w/out removing the turbo?? I've done this countless times on the older trucks, but I am kind of afraid of going this route with these new turbos? any chance of any tiny metal shavings causing problems with the sliding parts in the turbo??? or should I be ok if I grease the drill bit & tap really good, & also I've heard of people drilling the manifold with the truck running?? would this be a good idea???? thanks alot, Dusty
Old 10-09-2007, 02:24 PM
emf480v's Avatar
Dusty,
I drilled and tapped my manifold with the engine running and grease
on the tap and bit. Just have a glove handy and you'll be fine.
Old 10-09-2007, 08:29 PM
slauso's Avatar
I did mine with the truck off,no grease on the tap. I used a pencil magnet thru the hole to get the filings out after drilling and tapping. There was quite a bit of metal particles. I just kept using the magnate until no more particles came out of the hole.Worked excellent.
Old 10-09-2007, 09:00 PM
Luvnacumns's Avatar
I have done around 12 or so pyro taps with half each way... Both works!!!
Old 10-10-2007, 07:28 AM
thanks, think I'll take my chances doing it w/the turbo still on, let ya know how it goes! thanks again, Dusty
Old 10-10-2007, 07:53 AM
Luvnacumns's Avatar
make sure you wear safety glasses.....
ejb
11-03-2009 04:00 PM
Dusty Ratcliff
02-26-2007 06:36 PM
Lobo2055
06-25-2003 07:49 PM
Drafter
17
06-21-2003 11:07 AM
rattle_rattle
06-21-2003 12:02 AM
Quick Reply: thinking about putting my Autometers in, Pyro ?
