Strange exhaust sound
Old 04-17-2011, 12:11 PM
jamesbfishin's Avatar
Had a valve lash adjustment done about a month ago as well as a leaking cp3 replaced. Since that time I've noticed a strange sound that seems like its coming from the exhaust system. Sounds like someone is hitting the exhaust with a hammer, loud ping. It'll happen while I'm driving, and when I shut the truck down, thought it might have been the pipes moving as they cool but I can hear it while Im driving even after the truck has been running for an hr. any thoughts
Old 04-17-2011, 03:03 PM
Jeff in TD's Avatar
I guess I'd crawl under it when it is cool and look at the exhaust hangers and give the whole truck a good eyeballing, shaking and pushing on everything.
If that doesn't help, maybe when it is making the noise on cool down you could crawl around and isolate where it is coming from.
Old 04-17-2011, 03:32 PM
mq105's Avatar
It happens only while running, or also when the engine is off?
Old 04-17-2011, 04:23 PM
Happens while running and after I park and shut down, been under the hood to listen, shook every pipe and joint, checked all hangers, everything looks fine. No movement, everything is tight. Very strange, much louder than normal movement from cooling after shutdown.
Hard to tell where its coming from, under the hood sounds like down pipe or exhaust man, from under the truck sounds like the entire system
Old 04-17-2011, 04:58 PM
Adaminak's Avatar
One of the baffles in your muffler or the cat insert broke free somewhere and contracting at a different rate than the surrounding metal?
Old 04-17-2011, 05:03 PM
Has to be the cat then, muffler is gone. If Im running down a highway for an hour and there is a consistant temp running through the exhaust will a broken baffle or insert cause the hammer sound when there really shouldnt be that much expansion or contraction?
Old 04-18-2011, 09:36 AM
mq105's Avatar
If you hear the sound when the truck is not running, then it has to be an expansion/contraction issue, right? There is no mechanical movement when the truck is off. Exhaust manifold crack/leak?
Old 04-18-2011, 05:45 PM
That's the strange part about it, it does it after shut down and while I'm driving.....
Valv
04-11-2005 06:01 AM
Valv
04-01-2005 06:10 PM
thefb
09-21-2004 11:29 AM
masonic-dodge
09-13-2004 06:40 PM
Flashman
09-10-2003 06:02 PM
Quick Reply: Strange exhaust sound
