stock michelin tire pressure question
Old 04-09-2007, 07:50 PM
wreedCTD's Avatar
i run mostly unloaded and the stock michelins are still at the tire pressure from when deilvered, well over 50psi. i have read posts in the past that guys lower the pressure to make it ride better, any ideas what i should lower it to?
any affect on handling and tire wear?
thanks
Old 04-09-2007, 07:57 PM
35" 05''s Avatar
mine had 75lbs . I dropped down 35 in rear 40 in front or until it looks like they're not sagging. Better ride
Old 04-09-2007, 08:00 PM
nhboyd's Avatar
I keep my tires at 60psi. When I have my camper loaded I increase pressure to 75. I think the ride is better. I got about 30,000 on michelins.
Old 04-09-2007, 08:02 PM
wreedCTD's Avatar
i tried to check mine with a mechanical guage and they were so high, well past 50, i have yet to check with a electronic gauge.
My ride is very bouncy, especially on the highway.
Old 04-09-2007, 09:17 PM
CButler610's Avatar
Accurate statement. I think I run mine at about 42 in rear and about 50 in front. The pressure makes a big difference in ride quality.
Old 04-09-2007, 10:00 PM
donnee's Avatar
I usually keep em around 50# all the way around.
Ride seems to be ok but needing shocks.
Old 04-09-2007, 11:41 PM
Fishaholic's Avatar
Check your manuals. I had one the showed loaded and unloaded air pressures. I usually kept mine at 55 psi front and 50 psi rear without a load. I would't drop much below 50 on the front with the weight of a deisel, plus the lower the pressure the more heat build up in the tires.
Old 04-10-2007, 06:58 AM
MikeyB's Avatar
When empty I run 60 front, 50 rear. More interested in the handling than the ride.
MikeyB
Old 04-10-2007, 12:47 PM
TXOVAL's Avatar
I keep mine at 60#'s all the way around, just wondering how you got only 30,000 miles out of you michelins. I have the stock LTX A/S style and just got new ones at 96000. I hope this set last that long.
Old 04-10-2007, 01:52 PM
rockcrawler304's Avatar
I could be wrong but I think he means 30,000 miles so far, not total. I hope they go more than 30k.
I keep mine at 70 front and 60 rear unloaded. Getting very good wear and mostly highway driving for me.
Old 04-10-2007, 09:06 PM
TXOVAL's Avatar
I hope that's what he meant, I thought about that will driving home from work today.
Old 04-10-2007, 09:09 PM
wreedCTD's Avatar
i checked my pressure after about 30 miles ( i know i know) and the reading of the digital gauge was 50psi at all tires. i wonder if i am maxing out my gauges and need to get one for these high of pressur tires?
for as bouncy as i think the ride is i think the tires have more than 50psi of air, especially when hot.
4x4onTheSho
11-10-2007 01:46 AM
rcotton
06-23-2007 08:17 PM
tacohat
0
12-04-2006 10:59 AM
carpenterje
11-14-2006 01:15 AM
hotdram
09-23-2004 06:07 AM
Quick Reply: stock michelin tire pressure question
