Stock Injectors
Old Jan 5, 2007 | 09:46 AM
tomd's Avatar
Stock Injectors
Anybody know what type of injector Cummins might have (That are one step up from stock) that will gain in all areas, yet not too smokey? I have the IV turbo and would like to use it up near its potential. I would like to walk in and order a set over the counter using part numbers. Otherwise I’ll most likely buy the ones they have which run stock on my truck. They are not that smokey and give me good mileage, but is there something better?. Cummins has some injectors for about 85 dollars each, they are the ones that Cummins recommended or say are on my truck if stock.
Old Jan 5, 2007 | 10:26 AM
haloman's Avatar
Do a search for the bosch 190's. Moderate increase in power
Old Jan 5, 2007 | 11:07 AM
apwatson50's Avatar
I got the 190's and not real impressed with them, I would get a larger injector than you think you want and then just turn your pump down to where you like the power/smoke/etc. just not P.O.D's
Old Jan 5, 2007 | 11:51 AM
tomd's Avatar
Thats a good idea! Thanks.
Htt said they have a set of bosch that I'm about to look more into. I told them the same as above. Much cheaper too.
Old Jan 6, 2007 | 08:32 AM
angelfire7's Avatar
I just talked to Ross at Dynomite Diesel (866-7743960) he quoted me $1000.00 for a brand new set, not rebuilt or re-manufactured, but brand spanking new. I don't know if this is a good price or not. I've been watching the stickys and apparently a good rebuilt set will run you $800.00 or so.
Old Jan 6, 2007 | 11:32 AM
Begle1's Avatar
According to those Dynamite Diesel guys, the first gen injectors are only going to get more and more expensive as more of our cores get aged to the point of unusability. At least if you have brand new ones, they might be worth more (or even accepted) as cores later on.
jgiachino
May 12, 2008 02:06 AM
KRB
May 20, 2007 06:20 PM
cumminsdriver635
Aug 8, 2005 05:46 PM
sammy340
Apr 5, 2005 03:55 PM
BIGOKIE
Jul 21, 2004 05:53 PM
