Steering Column Squeek
Old 11-29-2006, 01:37 PM
4x4dually's Avatar
Anyone had problems with their steering column starting to squeek? It sounds like it is in the cab with me, but it may be propagating up the shaft or something. It seems to only squeek when I turn...naturally. I tried to search on the subject, but didn't find anything that I though was pertinent. Is there some bushings or gromments that I can lube up?
Thanks in advance.
Old 11-29-2006, 01:49 PM
TIMMY22's Avatar
on mine there is a bushing where it goes through the firewall (the gear selector arm area)
try some wd-40
Old 11-29-2006, 04:27 PM
4x4dually's Avatar
try some wd-40
Thanks, I'l try that. I got the WD, the Lithium spray, and the PB! Something's gotta work!
Old 11-29-2006, 04:40 PM
Gotlift01's Avatar
I have a weird growl in mine when I turn......it's been there ever since I bought it and I can't figure out what it is or where it comes from. I also have a squeek but it sounds like that's somewhere in the dash.........
~Nick
Old 11-29-2006, 06:56 PM
TIMMY22's Avatar
the growl is the bear, oh I mean the power steering pump. make sure there is enough fluid. you could look/change the fluid with the turkey baster trick. could be sucking air somewhere.
Old 11-30-2006, 04:27 PM
Gotlift01's Avatar
The power steerings fine ( it makes no noise at all )....the growl is actually coming from the column itself, sounds like it's right at the steering wheel. It's hard to explain.......
~Nick
Old 11-30-2006, 04:45 PM
Miles PH's Avatar
squeak
My truck has over 55K and the brake booster started speaking win I turned the wheel. Try steeping on the brake as you turn if it stops it might be the brake booster.Hope its not $750 bucks in parts later its fixed. NOT PART of drive train warranty Call D.C. no help at all.
Good luck keep us posted.
Old 11-30-2006, 05:02 PM
Gotlift01's Avatar
Holy lordy that's an expensive fix......I'll give her a shot when I get home tonight and see what happens. Thanks for the tip!!
~Nick
Old 11-30-2006, 07:48 PM
sjester's Avatar
Take a look at this. Seems to be working for quite a few folks on TDR for squeaks, clunks, etc http://www.rocksolidramtrucksteering.com/
04 Diesel
35
09-08-2009 08:43 PM
Idaho Guy
05-23-2008 05:40 PM
Ramdaddy
05-07-2007 09:37 PM
Txwelder
06-03-2005 07:34 PM
Ken W
07-23-2004 05:24 PM
Quick Reply: Steering Column Squeek
