Starts out in third gear
Old Mar 18, 2007 | 08:15 PM
Shane2403's Avatar
I have 2001 Dodge 3500 w/138,000 miles on it and I don't think it ever shifted right since I have had it. Sometimes it would stay in low till about 22mph then shift, like it was against the governor. It would do this at every time you came to a stop. Sometimes if you would wait 5 seconds and barely creeped forward it would shift into 2nd then 3rd quickly. This weekend I serviced tranny, which it has a 14 bolt pan, I don't know which transmission it is either, and there was nothing in pan but a little on the magnet. I adjusted the bands and put in a bottle of lucas transmission to help it, but it still does the same thing as before. To get it to low now you have to manual shift it. It kinda sucks because I know it has to be something electrical in trans. The detent is right on also because I checked it and it will downshift out of overdrive and from 3rd to second but it will not shift right on its own. Any info would be appreciated.
Old Mar 18, 2007 | 08:27 PM
phox_mulder's Avatar
Governor pressure sensor and solonoid.
Just had both replaced in mine a little over a month ago.
Exact same symptoms.
phox
Old Mar 18, 2007 | 09:02 PM
Silverfox99's Avatar
my truck also seems to do the similar but it usually takes off in second........how much do them parts cost?????
Old Mar 18, 2007 | 09:11 PM
I'm not sure.
Mine was covered under warranty, $100 deductable.
Mine was all over the place, starting in 3rd, starting in 2nd, starting in 1st but wouldn't upshift no matter what I did.
phox
Old Mar 18, 2007 | 09:26 PM
slowflyer2112's Avatar
Had the same problem on an earlier truck. I learned that it can be repaired without buying new gov. press. solenoids .
Go here: http://dunriteconverters.com/faqs.html
Hope this helps.
Mark
Old Mar 19, 2007 | 01:45 PM
Wolfeman's Avatar
Governor pressure solenoid and sensor cost about $200 from dealer.
Old Mar 19, 2007 | 02:09 PM
scottsjeeprolet's Avatar
Welcome to the DTR!
Phox ya missed that one.
Had 2 members of our chapter with the same problems and we changed out the pressure solenoid and sensor and that fixed it. Give it a shot.
PS Fill in your signature and location. Then Join your local chapter, we are here to help and you might make some new friends!
Old Mar 19, 2007 | 04:57 PM
Originally Posted by scottsjeeprolet
Welcome to the DTR!
Didn't even see that it was his first post.
phox
97catintenn
Jan 7, 2010 11:33 PM
DW Poyer
Oct 3, 2007 09:00 PM
FastSS
16
Mar 8, 2004 09:13 PM
tool
Feb 26, 2004 02:30 PM
tool
Feb 15, 2004 09:33 PM
