Starter Switch Torx bit info?
Old Mar 15, 2007 | 09:03 PM
broncobilly's Avatar
Anyone know what the NAPA part # is for the tamper-proof torx bit head, needed to remove the three torx screws on the ignition switch? The FSM lists TTXR15A2 as the Snap On part #. I just want to see if NAPA had the same tool for less $? TIA!
Old Mar 15, 2007 | 09:35 PM
woodrat's Avatar
NAPA is where I got mine, but I don't remember the part number. I think I bought a couple of different bits that would fit my ratcheting screwdriver and one of them was the right one.
Old Mar 15, 2007 | 11:03 PM
dpuckett's Avatar
I got a whole set of them from AutoZOne for about $10. From about T10 to T35 or 40.
Daniel
Old Mar 16, 2007 | 12:16 AM
Thanks, I'll have to go to NAPA and see what they have? I bought a swiss army style torx bit kit at Ace Hardware. It has the right size torx bit head, T15, however - it won't work due to the anti-theft pin in the middle of the torx head - on the ignition switch
Old Mar 16, 2007 | 08:21 AM
They are known as security torx.
Old Mar 16, 2007 | 10:17 AM
woodrat's Avatar
you could just knock the pin out of the middle with a smal punch and use the regular torx too.
Old Mar 17, 2007 | 12:03 AM
Thanks all for the help! I ordered a set of security torx bits from NAPA, $21 and some change. I was going to use a punch on the security torx screws, as Woodrat suggested. I figured, as I am ham fisted, I would probably break the steering column
tnhtractors
Feb 2, 2009 09:34 AM
Joes truck
Jun 2, 2007 11:09 PM
04ctd
Nov 25, 2006 07:30 PM
jeeptjstud
Dec 14, 2005 05:15 PM
