do I need the special torx bit for 99 CTD
Old Dec 13, 2005 | 09:54 PM
jeeptjstud's Avatar
do I need to buy the torx bit from bluechip to get the stock VP44 pump cover off a 99 dodge to replace it with a new one or can I find the bits at checker auto?
Old Dec 13, 2005 | 10:09 PM
dieselrob's Avatar
It is a tamper proof torx bit. It needs to have a small whole in it.You should be able to find one at and auto store or sears mabey.
Old Dec 13, 2005 | 10:56 PM
BigBlue's Avatar
Good luck finding one. I called every autoparts store in houston and every sears and home depot and lowes and any other place that sold tools and not a single one of them had one. Half of them had never even heard of a tamper proof torx bit.
Old Dec 14, 2005 | 12:13 AM
DodgeCowboy's Avatar
DTR's Cow Boss
go to a place that deals with electrical supplys only like the places that electricans get there supplys from not el chepo or lowes or any place like that they have tools for tamper proof torq screw drivers for some of the tamper proof light fixtures used in parks and public restrooms.
Old Dec 14, 2005 | 12:18 AM
Joe Mc's Avatar
Try www.grainger.com or, www.mcmaster-carr.com. If it looks like a torx with a hole in the center it's a standard security screw bit. Either of the mentioned outfits should have them.
Old Dec 14, 2005 | 05:41 AM
Shovelhead's Avatar
Administrator / Scooter Bum
You'll need to check to be sure.
My '99 had standard Torx bit screws.
Old Dec 14, 2005 | 08:03 AM
jfpointer's Avatar
I bought a set made by Lisle off eBay. I think they were about $8 or so, but it's been a while so that may be wrong. I got them for work; we had a bunch of Compaq computers that required the tamper-proof Torx to open the case if the power supply failed with the lock in position.
Old Dec 14, 2005 | 08:19 AM
RickCJ's Avatar
My new pump had torx looking tamper proof screws holding the cover on.
They are 5 point not 6 like the torx are, my torx tamper proof will not fit! So I just tapped the wire. Your 99 should have regular torx!
I didn't use my cover, wanna buy it?
Old Dec 14, 2005 | 08:20 AM
Big Deezul's Avatar
I am pretty sure thats is on 2000 and up. On my 98.5 I did not need them. Just look at the bolts on your stock VP cover...thats what they are for
Old Dec 14, 2005 | 12:13 PM
mcoleman's Avatar
The package that came with mine says tamper resistent. I bought them at Oreilly's when I had to change out the ignition switch.
Old Dec 14, 2005 | 01:35 PM
John Faughn's Avatar
When I first came accross these in the shop , and needed to get the car back to the customer , I just took a small punch and knocked the center peace out and then used a regular torx , then bought more tools from snap on , this an endless bs thing with never beening able to use the tools you already have , it seems sometimes that you need to buy a new set off tools every 6mnths. then I got ripped off [ about 70,000 worth of tools ] and now do not have to keep up becouse I'm no longer working as a tech. I used to like working as a tech but with all the issues [ hazerdouse invierment , high cost of being a tech and the low pay compaired to time & money spent to do it ] I'm almost glad that there gone except for working on my own stuff.
Old Dec 14, 2005 | 03:23 PM
oestreich84's Avatar
I did almost the same thing. I put my regular torx bit in a vice and used a small drill bit to put a "dent" in the end. Works for everything! I also went through getting tools stolen. About 6 months ago I forgot to lock my bottom box and came back in the morning with everything missing out of the bottom box. Probably about $15,000 worth of tools. Thank god I locked my top box, because I could still work on most of the stuff that came in.
Old Dec 14, 2005 | 05:15 PM
jeeptjstud's Avatar
how much do you want for your cover, I sent you a pm
tnhtractors
Feb 2, 2009 09:34 AM
Joes truck
Jun 2, 2007 11:09 PM
broncobilly
Mar 17, 2007 12:03 AM
04ctd
Nov 25, 2006 07:30 PM
