What To Stack With Mp8 ?
Old 04-11-2007, 12:01 AM
RACER47's Avatar
I have an 03 so with an MP8, intake, and exhaust, gauges.
First question is what would you guess my RWHP is at this point?
Second question is what would best stack with the MP8, and what would the RWHP be with that stack?
I am looking for the best of both worlds. Something I can play with when I want to smoke a furd, and something that is ok to tow with. I know I should think about a turbo, but I don’t have a clue what to get. Any help in that area ?? I don’t want to loose to may MPG. but I realize there may be a trade off there
Old 04-11-2007, 12:04 AM
Luvnacumns's Avatar
SMARTY!! I have them stacked. and OMFreakinG!!!! The power is insane.. I have the smarty on 7 and mp-8 on 40%. Towed with it today and everything egt's were at 1100 for a little while but other than that right around the 800-850 mark..
Shane
Old 04-11-2007, 12:07 AM
RACER47's Avatar
Is that with a stock turbo?
Old 04-11-2007, 12:08 AM
Luvnacumns's Avatar
Yeah for another two weeks then I will have the Aurora 5K..
It will hit 40 psi notin flat..
Shane
Old 04-11-2007, 12:27 AM
tristan21's Avatar
Hey you guys might/should want to add a fuel filter on that/ GDP or FASS becouse I know that pressure boxes, like the mp-8, need really clean fuel to keep from killing your injectors. By the way I have an mp-8 on order.
Old 04-11-2007, 12:36 AM
powerstrokin03's Avatar
yes he does
Old 04-11-2007, 06:49 AM
wap
wap's Avatar
stack it with a tst and you have a pretty potent combo. Cant speak for the smarty stack though, never tried it. SHOULD have a better low end but not quite as much up top.
Old 04-11-2007, 07:48 AM
MOJO1's Avatar
TST worked out real good on my 03.just not my 06
Old 04-11-2007, 08:37 AM
53 willys's Avatar
what didn't you like about it????
Old 04-11-2007, 08:48 AM
Id run the smarty, when i had my MP-8 stacked with the smarty it helped keep up the pressures....and the smarty uses alot of pressure with the added pressure EGTs also went down some.
Old 04-11-2007, 10:01 AM
MOJO1's Avatar
53 ****** It just didnt work at all rough idle CODES! all the time truck just didnt seem to run at all took it back alot still no good they said some of the later made dodges it didnt work on. It says it on there site.
But it rocked on my 03&05!dodge
Old 04-11-2007, 02:57 PM
Mark1si's Avatar
I'd say Smarty. The TST on my truck is like yea ok bla.
Old 04-12-2007, 05:54 PM
RACER47's Avatar
So with the smarty- MP8 stack, what do you think the RWHP would be?
Old 04-12-2007, 05:59 PM
Luvnacumns's Avatar
What setting's??? I am running the smarty on #7 and mp-8 on 40% but I don'g have a clue what the rwhp would be... FAST!! What blows me away is how well the turbo keeps up for a stocker. I can hardly get any smoke.. The only time I get smoke is if I bog the turbo down and once it gets caught up it clears up just fine..
Shane
Old 04-12-2007, 06:04 PM
RACER47's Avatar
Do you plug the MP8 into the smarty or smarty into MP8?
Quick Reply: What To Stack With Mp8 ?
