What To Stack With Mp8 ?
I have an 03 so with an MP8, intake, and exhaust, gauges.
First question is what would you guess my RWHP is at this point?
Second question is what would best stack with the MP8, and what would the RWHP be with that stack?
I am looking for the best of both worlds. Something I can play with when I want to smoke a furd, and something that is ok to tow with. I know I should think about a turbo, but I don’t have a clue what to get. Any help in that area ?? I don’t want to loose to may MPG. but I realize there may be a trade off there
SMARTY!! I have them stacked. and OMFreakinG!!!! The power is insane.. I have the smarty on 7 and mp-8 on 40%. Towed with it today and everything egt's were at 1100 for a little while but other than that right around the 800-850 mark..
Shane
Shane
Hey you guys might/should want to add a fuel filter on that/ GDP or FASS becouse I know that pressure boxes, like the mp-8, need really clean fuel to keep from killing your injectors. By the way I have an mp-8 on order.
Id run the smarty, when i had my MP-8 stacked with the smarty it helped keep up the pressures....and the smarty uses alot of pressure
with the added pressure EGTs also went down some.
53 ****** It just didnt work at all rough idle CODES! all the time truck just didnt seem to run at all took it back alot still no good they said some of the later made dodges it didnt work on. It says it on there site.
But it rocked on my 03&05!dodge
What setting's??? I am running the smarty on #7 and mp-8 on 40% but I don'g have a clue what the rwhp would be... FAST!! What blows me away is how well the turbo keeps up for a stocker. I can hardly get any smoke.. The only time I get smoke is if I bog the turbo down and once it gets caught up it clears up just fine..
Shane
Shane
