Squeek in Suspension
Old 03-06-2007, 02:55 PM
TireHauler04's Avatar
Question Squeek in Suspension
After the last long trip I took this past weekend, i now keep hearing a metal to metal type long drawn out squeeking coming from the drivers side of the front end.It pops and squeeks really loud going into driveways and over speedbumps...anyone know what this is?Could it just be a bushing or something needing grease?
Old 03-06-2007, 06:48 PM
infidel's Avatar
Could it be your brake pads are worn out and the indicator "squealer" is rubbing?
Old 03-06-2007, 08:11 PM
clutch1's Avatar
my dad's 94 would make a loud grinding squeak from under the front spring where in sat under the tower, can you hear it while bouncin on the front end If you can spray some penetrating oil at that point just to see if it quiets down any.
Old 03-06-2007, 08:21 PM
Fueling around's Avatar
Check your top door hinge. Bushing may be worn though.
Old 03-06-2007, 08:52 PM
HAHA...it's not the door hinge.I may try blasting the whole under side with oil see what happens.
Old 03-06-2007, 09:07 PM
TIMMY22's Avatar
could also be your hub. low speed popping in 4wd during turns would be front axle u-joints.
Old 03-06-2007, 10:03 PM
Box5's Avatar
probably a worn bushing
Old 03-13-2007, 03:57 AM
Jim Lane's Avatar
Check the Strut rod bushings also where they bolt onto the lower arm.
Have someone drive the truck a few MPH and while you are watching the front end, have them stop abruptly and see if the front wheel moves forward or rearward.
Jim
04 Diesel
35
09-08-2009 08:43 PM
Txwelder
06-03-2005 07:34 PM
Ken W
07-23-2004 05:24 PM
DuallyJeff
04-23-2003 09:01 PM
Quick Reply: Squeek in Suspension
