Squeaking 4wd shifter
Old 05-12-2007, 07:36 AM
claymeis's Avatar
Ive got an 07 5.9 4wd quad cab with 7500 miles. The 4wd box where the shifter comes through to the cab squeaks terribly while driving (usually in 2wd). The shifter and transfer case moves with the engine torque while driving and is causing this. Anyone else have this problem? Any suggestions to cure it. Its anoying as hell!
Thanks,
Clay
Old 05-12-2007, 07:57 AM
HdPower's Avatar
My 04.5 did this quite a bit...IIRC I sprayed some silicone or something on it and fixed it temporarily. DO a search here I think there is a better answer to fix this.
Old 05-12-2007, 10:52 AM
claymeis's Avatar
Thanks. I did a search and found nothing that was relevant to a 6spd, just automatic squeaks.
Old 05-12-2007, 08:17 PM
HdPower's Avatar
Here's one link....down at the bottom someone links to more possible fixes.
https://www.dieseltruckresource.com/...shifter+squeak
Old 05-13-2007, 10:42 AM
white06's Avatar
mine just started doing the same thing after i had my clutch replaced .
Old 05-13-2007, 11:58 AM
64camo's Avatar
Mine did the same thing. I popped the rubber boot for the shifter up and sprayed WD-40 on the linkage. Snapped the boot back in place and have not heard another squeak out of it.
coalburner400
15
01-19-2008 03:09 AM
dsljunkie
04-22-2003 09:37 PM
8secondride
04-01-2003 10:00 PM
8secondride
04-01-2003 09:55 PM
0
03-20-2003 04:25 PM
Quick Reply: Squeaking 4wd shifter
