rattlin 4wd shifter
Old Apr 10, 2003 | 12:01 PM
dsljunkie's Avatar
rattlin 4wd shifter
Ok my 4wd shifter has been rattlin every since I bought my truck and its finally drove me crazy . It will shake around especially on my dirt road and make a hidious Klack ity Klack ity Klack noise . Has anyone else had this problem if so what did you do... PLEASE help! <br> Wheels
Old Apr 10, 2003 | 12:50 PM
riffman's Avatar
Re:rattlin 4wd shifter
my buddies doesn't really go clickity clack...but more of a sound like a CD case rattelin in the door pockets...ya know?<br><br>his is a 97 3/4 ton 4x4 extended cab auto CTD...
Old Apr 10, 2003 | 06:12 PM
bulthisl's Avatar
There is a spring on the T-case shifter that will lose it's tension and cause this.<br>Remove boot and tighten the tension on this spring and it should stop this prob.<br><br> : Eddie : 8)
Old Apr 11, 2003 | 07:24 AM
turbospl311's Avatar
And there is a TSB on getting this fixed. Dealer did mine for me when he was fixing the rear end he broke by not lubing it.<br><br>Don Miller<br>97 2500, #8 plate, 3k springs, PDR 370's, Scotty II, 16 deg timing, custom Trans by Frank.<br>
Old Apr 11, 2003 | 09:47 AM
berner's Avatar
I took an exhaust flange spring (looks like a valve spring with one narrow end) and inserted it in the space below the side-to-side shifter pivot. The existing spring ends go through the tabs and hold the new spring in place. The shift lever ends up being pushed towards the passenger side. I compressed the spring with needle-nose Vicegrips and propped a stick between the shifter and the drivers kick panel to open up the gap. Tricky to get the spring in but it worked like a charm.<br>p.s. Wear safety glasses. I had that spring go wizzin past my head at about 100mph.
Old Apr 11, 2003 | 10:41 AM
doodah's Avatar
I just put a very small, very stylish bunji cord around and hooked both ends under nieth dash- keeps her quit for now! ;D
Old Apr 11, 2003 | 11:08 AM
dodgeman01's Avatar
[quote author=doodah link=board=5;threadid=13444;start=0#126945 date=1050075674]
[/quote]
Yeah they have many colors to choose from. I used the red white and blue one. ;D
DM01
Old Apr 11, 2003 | 11:52 AM
dsljunkie's Avatar
Thanks guys I'll have to take it apart and check it out.... or maybe those bungees will do the trick . But this will have to wait until I figure out why my truck wont stay runnin :'(. Just happened this mornin :'(. It would crank up but it just wouldnt keep an idle or anything .<br> Wheels<br><br>
Old Apr 12, 2003 | 07:24 AM
Dodgezilla's Avatar
The 92 I had did it from day one. I got so tired of hearing it that I finally put a moving blanket over it and kept the radio up loud. I took it to the dealer several times and they could never fix it..
Old Apr 22, 2003 | 09:37 PM
brassbuldog's Avatar
I stuck my paint bomb can between the shifter and the side wall to stop the annoying rattle!<br>
jjdiesel1990
Sep 2, 2007 09:48 PM
RATTLINRAM
20
Aug 2, 2004 10:30 AM
Palmetto_kid
Jul 2, 2004 08:19 AM
RATTLINRAM
22
Apr 22, 2004 10:58 PM
acoustic_axe
Feb 2, 2003 09:00 AM
