Solid steel ind. track bar ?
Old 05-19-2010, 10:13 PM
Derek Roch's Avatar
Hey guys i bought and installed the solid steel adjustable track bar for my 01 this past weekend and i was wondering what is the correct or most percise way to adjust and center the front axle? I eye balled it and it looks pretty close but i would like to make it as perfect as possible.
Old 05-19-2010, 11:48 PM
nickg's Avatar
4ft straight edge laid against the tire (vertical) and the fender, on my truck it worked perfectly, straight edge touches fender and top and bottom of tire
I'm running 265-70-17 on 3rd gen rims.
or you can break out a tape measure and measure like points between frame and axel
Old 05-20-2010, 11:54 AM
01RAMer's Avatar
Actually, if you didn't try to straighten the steering wheel yet, just adjust the track bar till the steering wheel is in the correct position and you'll be back to where you should be. If you already adjusted the steering wheel, then you going to have to do some measuring.
CTD2001
08-22-2009 10:03 PM
horselady
22
01-10-2008 11:24 PM
afoulk
09-06-2007 11:23 PM
just_crankin_it
13
06-01-2007 04:12 PM
6 Shaker
01-18-2006 06:00 PM
Quick Reply: Solid steel ind. track bar ?
