smarty senior,Level#1 Quad boost fooler= towing bliss
Old 09-13-2009, 09:49 PM
dfranks's Avatar
I was towing my 34'TT (8000lbs wet)on #3 and found it running a bit on the hot side 1300-1400EGT's on T/haul in OD in the hills,averaged 1100-1220 on the rolling flats.It also had enough power not to downshift very often. If I kept it out of overdrive the truck was running way cooler, but was a bit loud (2500-2600rpm) to maintain 70MPH on our freeway.
Anyways I changed to level 1 and my temps dropped about 100F across the board. BUt it will downshift earlier now than before on #3
I added the quad boost fooler and it took another 100F off of it and seemed to be closer in power to the #3. It also seemed to hold O/D a lot longer than on #1 alone.
So I found my combination for towing in the mountains. It also feels a tad bit smoother in acceleration but that's probably wishfull thinking on my part.
Old 09-13-2009, 10:10 PM
annabelle's Avatar
I thought the Smarty had boost fooling.
Old 09-14-2009, 07:11 AM
dfranks's Avatar
The short version to that question is YES, but to a certain amount.This is where a piggyback fooler can benefit the 5.9l Thanks to the extra fuel developed by the smarty. It so far seems to be a nice fit for me.
I notice a benefit in cooling which is what I wanted.
Do a search on the smarty boost fooling. You could read for hours.
Old 09-14-2009, 07:27 AM
annabelle's Avatar
jmccart
04-05-2011 06:13 PM
BigJohnston
07-16-2008 09:00 AM
jmccart
12-21-2007 06:00 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
rkelley
19
01-11-2007 10:59 PM
Quick Reply: smarty senior,Level#1 Quad boost fooler= towing bliss
