Smarty Loading Problem?
Old 06-19-2007, 08:39 AM
HOOKED's Avatar
My smarty downloader when i first got it only took 3 minutes to load(Smarty to truck) now it takes over 15 min to load? Can anyone figure this out? And i have tried 2 different smarty's same outcome.
Old 06-19-2007, 11:07 AM
Bob Wagner's Avatar
what year truck?
Old 06-19-2007, 02:53 PM
HOOKED's Avatar
2004.5 manual
Old 06-19-2007, 02:55 PM
Big T's Avatar
Mine Takes alot longer know also it is a 2006 automatic
Old 06-19-2007, 02:58 PM
Bob Wagner's Avatar
Hooked the CR smarty never had a download time of 3 minutes. The VP44 is the shortest download time of them all
Old 06-19-2007, 03:19 PM
HOOKED's Avatar
Ok 5 minutes max... It never took 15 or more minutes...
Old 06-19-2007, 03:34 PM
Bob Wagner's Avatar
its never been less than 10 prolly closer to 12
Old 06-19-2007, 04:31 PM
HOOKED's Avatar
Im trying to figure out what happened to "The customer is always right" saying i have posted before about SMALL smarty issues and always get the BS alert from you. I understand im not a professional but i am simpily stating a concern i am having thats it. Why cant i just get a straight answer like "i will look into it"? I just wanted to know if it was something to worry about or is this normal? I have loaded the same smarty on the same year of truck and it took just a bit over 7 minutes... Yes i timed it for the simple reason i new it was taking longer on my truck. Im simply stating my expierence with the smarty.. You have said this yourself no two truck are alike.
Old 06-19-2007, 04:35 PM
Bob Wagner's Avatar
I am simply trying to help. Did you happen to switch from an s04 smarty to a s06 smarty?
The s06 smarty has more software and that may be the difference.
Since the beginning Marco is always make the ecm tune time shorter eith quicker boot upgrades.
How can I help you? The cummins ecm is rated for 100K flashes.
Old 06-19-2007, 04:36 PM
Bob Wagner's Avatar
and the last time I heard from you was when you had an issue during the ice storm and then that was it.
I am here to help you
Old 06-19-2007, 04:49 PM
HOOKED's Avatar
I downloaded the newest software back then and nothing seemed to get it fixed so i decided to live with the generic stock software. i could not find what version the dealer flashed it last... Anyways that is a dead issue... This uploading time was just a concern not a problem i was a little curious what was causing it,and if i should be worried?
Old 06-19-2007, 04:54 PM
Bob Wagner's Avatar
there should be nothing to worry about and check the software code.
its fast and free
Cruizer
01-31-2009 07:55 PM
paroxysym
15
03-10-2008 09:24 PM
jmccart
12-09-2007 12:58 PM
trx
10-04-2007 10:17 PM
qwest
02-06-2007 04:22 AM
Quick Reply: Smarty Loading Problem?
