Skyjacker front springs, good or bad?
Old May 15, 2010 | 09:27 PM
huntinguy's Avatar
I've seen mixed reveiws on Skyjacker and I want to know what you guys thing. I need to get a set of 4" springs for the front. Here is a pic of the truck with just the rear lifted. Kind of got that sled puller look to it.
Old May 15, 2010 | 10:57 PM
rswoyer's Avatar
I know everyone has their opinion on skyjacker springs; I put 2 1/2" lift springs on my '93 and put 4" lift springs on my 91. Both sets have made the ride on each truck a little easier on the kidneys and after 1 year have not sagged at all. Other people have had horror stories with them. I was just lucky I guess.
Old May 16, 2010 | 06:04 AM
Tater93's Avatar
Mine have been under the truck since early 2007 and they don't sag at all. I think Skyjacker makes quality products but I have also seen some mixed reviews.
Old May 17, 2010 | 09:25 AM
huntinguy's Avatar
Bump. anyone else?
Old May 17, 2010 | 12:00 PM
matchew's Avatar
I have the 6" on mine... got them used but they seem good to me, maybe settled a bit, but what to expect? All springs will settle after use... some sooner than others.
Old May 17, 2010 | 04:16 PM
Benjamin b2's Avatar
i have 2" leveling skyjacker springs in the front and 6" block delete springs in the back. in 10 years the only thing that has broken, is the front spring eye bolt in the front that came with the kit from hittng an irrigation ditch at a high rate of speed. HIGHLY recomended for ride comfort.
Old May 17, 2010 | 05:02 PM
Kenny D's Avatar
i had skyjacker 6 lift on my 97 on 38s whne off road evyr week for a good year in WY and never had a problem and i have them on my 05 dually with a road armor bumper and still no sag or problems i recomend SKYJACKER
Old May 17, 2010 | 05:07 PM
Midnite's Avatar
I put a Skyjacker leveling kit in my 1992 and loved the heck out of it. The ride was so much better compared to my worn out stock springs. I'd do it again for sure.
Mike
Old May 17, 2010 | 07:13 PM
big stinky's Avatar
A buddy of mine put a set of 4" in his truck, it sagged a noticeable amount on the drivers side...
Old May 18, 2010 | 08:51 AM
Paul S.'s Avatar
I have the front 2 1/2" (leveling) diesel springs. Mine have been on since 2006. The ride is significantly better, that being said mine sagged within a year. They are not as low as the factory springs I replaced but they are certainly not where they were when I installed them...
Overall I would recommend them for the ride improvement if you are not too concerned about the lift. If you were after the lift I have heard going with the 4" is way, they ride well and they get the truck level, unloaded of course...
Old May 18, 2010 | 09:00 PM
91.5CTDBanks's Avatar
I put on a used set of 4" skyjacker springs. Been on the truck 2 yrs and on another truck a yr. Still look good, no sag.
Old May 18, 2010 | 09:16 PM
93John's Avatar
I have a 4" skyjacker lift on mine. The previous owner put it on not very long after he bought the truck. They have saged a little. I have also had a few broken front shackle bolts.
Old May 19, 2010 | 10:42 AM
I have two V-8 Dodges a '85 crew and '72 stepside with Skyjacker 6 inch lift springs front and back.
The '72 has been lifted since the winter of '99.
It has seen some VERY hard wheeling on its 38.5 x 15.5 Super Swampers.
The crew has been lifted for 4 years, and only sees light duty wheeling / camping / fishing / hunting trips. The crew runs 37 x 13.5 radial Dick Cepeks.
I cut both of the trucks front wheelwells to make the tires fit on 10 inch wide 15 inch rims.
I have seen the drivers side settle on both rigs to the tune of about 3/4 on the Crew and 1 inch on the Mudder more than the passenger side.
They ride great and I have had no problems with them other than the settling in the front
Old May 19, 2010 | 05:19 PM
jeff77indy's Avatar
Not to steal this thread but what would the best route be to get my W350 cab and chassis back to factory height?
The front springs are pretty tired and figured to replace the rears while I'm at it.
Will the Slyjacker W350 kits work on a cab and chassis?
Would the 2" lift in front and say 6" in back without any blocks be a way to go?
Any input would be appreciated.
Jeff
Old May 20, 2010 | 06:04 AM
Mclair's Avatar
I have a W250 and was wandering the same thing i have the 2 1/2 springs in front but my back springs are shot would 6inch spings with a block delete be the way to go and I tow alot are they strong enough for that?
