what size is the nut for the rotor assy on 2wd truck
Old 03-22-2010, 06:34 AM
westport's Avatar
I just bought a 1996 2wd with 282K miles. ONe of the things I want to get done is to repack the wheel bearings. What size of socket will I need to remove and install the nut that holds the rotor/bearings onto the spindle?
Old 03-22-2010, 11:48 AM
Sea:\>Drive's Avatar
If it is like an '01 it is a sealed hub assembly and can't be repacked. Sorry I'm not much more help.
Old 03-22-2010, 09:12 PM
GAmes's Avatar
To remove it should only take your finger tips. I use a big crescent on reinstall. Good-n-tite, spin the rotor to seat the bearings then back it off. Finger tight and install the cotter pin.
Old 03-23-2010, 08:50 AM
MATTIEBOB's Avatar
i usually use a big pair of channel locks, and the procedure is the same as what GAmes said.
wisconative
05-13-2013 07:20 AM
Clane
06-02-2012 03:31 PM
smooth89
04-14-2011 04:36 PM
9512vCTD
12-09-2006 02:25 AM
RK Deadeye
08-26-2005 10:14 AM
Quick Reply: what size is the nut for the rotor assy on 2wd truck
