What size jammers?
What size jammers?
I'm looking at getting a set of edge jammers but keeping the stock turbo for now but will upgrade in the future just not right away. I don't tow more than a few dirt bikes, quads or a small boat, but will be pulling a trailer across the country from alberta to Nova Scotia. I'm moving and don't know how much the trailer will weigh but will the stock turbo handle stage 5's with the comp turned all the way down or would 3's be better?
I've towed some with my 5's and stock turbo. I always have the smarty on SW5 or SW7. I will admit that I do not tow often or heavy though.
I lock out od and keep the rpm on the high side I generally don't have any issues. I run about 60-65 mph at 2500 to 2700 rpm. Towing my 5,000# boat around is absolutely no problem. The road to the lake I go to is long and straight, but has pretty steep hills up and down for about 20 miles and I have had zero problems. Now towing a bobcat and trailer (guessing about 10,000#) things get a lot warmer. It's not too bad once you get moving, though.
The bigger problem for me is the trans, but it looks like you have upgraded yours some. Anyway, these are just my experiences...hope it helps.
Brad
Brad
storx
09-04-2005 04:07 AM
Mixer Man
08-04-2005 08:00 PM
FiverBob
41
12-16-2003 06:14 PM
