simple twins question
Old 12-20-2008, 08:02 PM
82NDSNPR's Avatar
who is running the II race setup bullet and brother combo and what is the biggest numbers anyone has seen with this setup? its twin time and i am looking around trying to save some cash since i run the bullet already
Old 12-20-2008, 08:30 PM
mulisha's Avatar
how about an s400, or s480 and be done with it.no charge lol.
Old 12-20-2008, 08:36 PM
82NDSNPR's Avatar
see you all talk the s400 and 480s but i have no clue what that is lol. that is why its been so long on a single. i need to get some knowlage.
Old 12-20-2008, 08:39 PM
53 willys's Avatar
this guy did some pretty nice numbers with the II race twins...
http://www.dieselbombers.com/5-9l-cr...40-ft-lbs.html
Old 12-20-2008, 08:41 PM
mudder500's Avatar
923 a guy out of texas did with 65lpm injectors. Said truck wouldnt clear smoke at all even normal driving.
Old 12-20-2008, 08:43 PM
mudder500's Avatar
The turbos on that truck are pretty maxed out cept for the spraying part
Old 12-20-2008, 08:49 PM
82NDSNPR's Avatar
man i would be happy with 800-900 hp i would like to keep her steetable though lol. just seems like its never enough and since i got the bullet unless there is a set out there that will performe hands down better i want to save some cash since i need to ring the head and buy my dual pump.
Old 12-20-2008, 08:59 PM
mudder500's Avatar
Dont worry bout ringing the head till u have a problem. I got 3900 in my silverbullet over 480 combo. I should do right at 900 with my setup and its a dailydriver
Old 12-20-2008, 09:39 PM
82NDSNPR's Avatar
so what is a 480 and how much does the turbo cost
Old 12-20-2008, 09:59 PM
dieselram_04's Avatar
basically you are running a s300 or s366 since the bullet is a 66mm wheel a s480 is a larger frame version of the s300 most typically on a t-6 foot atleast for diesel apps and as the name implies has a 80mm inducer. I am getting a S480 with a 80mm inducer t6 flange 1.32 A/R ratio w/ a 96 turbine wheel. most say a 64 over a 480 is good to almost 1k hp whether its on fuel only or not i couldnt tell you. PS most can be had for under 1500 take a look at the super dave from HTT.
Old 12-20-2008, 11:29 PM
dieselfan's Avatar
s480 is made by borg warner. toolman on here has one for sale, the piping too.
Old 12-20-2008, 11:47 PM
82NDSNPR's Avatar
sweet you guys rule
Old 12-21-2008, 08:37 AM
mudder500's Avatar
Wicked diesels has a whole kit for sale also. He will build to specs of whàt u want
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
dodgediesel
17
04-05-2011 11:21 AM
Stock 02
28
09-24-2006 11:09 AM
Quick Reply: simple twins question
