Shudder At Low RPM
Old 02-21-2008, 08:53 PM
teamroper12v's Avatar
Shudder At Low RPM
I am new here, but I have the a problem with a 95 ctd in a ford truck that I did a conversion on. I have a 6 speed and when I put in my 90hp injectors I got a terrible shudder anywhere from 1000 to about 13 or 1400 rpm. I can just fuel through it and it stops. It never did it with the stock injectors and that is the only thing that changed before the problem started. Any advice would be great.
Old 02-21-2008, 08:55 PM
JFlory's Avatar
What clutch? If it's stock, it is going out. Mine did the same thing when I put in the Mach 4's and bigger turbo.
Happy SB DD owner now.
JD
Old 02-21-2008, 09:04 PM
Its in my sig. It is a Zoom button style stage II. I think that it is rated at 650hp/1300tq. Thanks.
Old 02-21-2008, 09:06 PM
Also, I would not be able to fuel through it if the clutch was slipping, it would just free rev. It only does it under low throttle situations.
Old 02-21-2008, 09:31 PM
seabee's Avatar
were did you get the injectors from they might be bad.did you make sure you used new copper washers when put the new injectors in.
Old 02-21-2008, 09:38 PM
They came from a friend, I am not sure where he got them. I did have the pop tested before I installed them and they were all within 5% of each other.
Old 02-21-2008, 10:54 PM
Tate's Avatar
Would it be because they are marine injectors?
Old 02-21-2008, 11:46 PM
Not sure, hoping that someone will give me an answer to questions like that. I need all the help I can get with this one. Thanks for the suggestions guys.
Old 02-22-2008, 09:55 AM
aksparkey01's Avatar
hmm. make sure that your govenor arm isnt hanging up. after that i would check the filter and overflow valve. I ran the 300 marines for awhile with no stumble paired with stock dv's.
Old 02-22-2008, 07:57 PM
ILLINOISRAM's Avatar
I just finished a truck today that was doing the same thing. Changed out injectors and it went away. It was a 95 4x4 auto. I put a new inj pump, injectors and lift pump from pensacola diesel. The truck ran fine, but shudderd at about 1150. I took the stage one's out and put in factory bosch 275 and truck runs perfect. Tim
Old 02-22-2008, 08:33 PM
I have been talking to my performance guy and I think that we have figured it out. He said that he has had this problem with several 94 and 95 trucks that have had larger injectors, so here is what we did. I know in my sig it says 191s, but I just finally got around to putting them in tonight and it basically fixed the problem. It still has a very minor shudder, but you cant hardly feel it at all. Also, it moved it down to about 950 or 1000 rpm and that is low enough that you should not be down there much anyway. I hope that this helps some having the same problem.
Rafter B
04-13-2008 09:40 AM
city slicker
10-24-2007 10:23 PM
Breck-Ram2500
06-02-2006 07:47 PM
spitzair
01-24-2006 03:42 PM
fishin fever
02-22-2004 08:32 PM
Quick Reply: Shudder At Low RPM
