should i chip my truck?
Old 07-02-2010, 08:12 PM
02dodge_cross's Avatar
i have an 02 dodge cummins and it have 298000 miles on it. all of my friends want me to chip it, but my relatives say ill blow the engine up since it has all the miles on it. what do you guys think?
Old 07-02-2010, 09:00 PM
J Lent's Avatar
I think you should do a fuel system first, then chip it.
Old 07-03-2010, 12:28 AM
lovinCTD59's Avatar
I would get a good set of gauges, and a reliable fuel system first. After that go for it. These engines are so layed back from factory, they can take PLENTY more!
Old 07-03-2010, 01:58 AM
nickg's Avatar
mine has 500,000kms(312,000miles) and has been chipped since 340,000kms,(212500miles) engine is the last thing to worry about, fuel system/ tranny/ will be more stressed by a chip
Old 07-03-2010, 02:05 AM
kerry.king's Avatar
I gotta agree with the other guys. Gauges, pyrometer, fuel pressure, boost, tranny temp, and fuel system before anything else. Better get a fass or airdog on there asap before you kill your injection pump. It was a lesson I learned the hard way.
Old 07-03-2010, 07:57 AM
J Lent's Avatar
I would get a fuel system first, then worry about planting the power. You will need either a good clutch or a built auto to handle the power. Then you can start adding power. If you choose a module like ADR/Pulse, you will have your gauges.
Old 07-03-2010, 02:38 PM
Thanks, how much power to you think i should put into the truck? Im wanting to put on a chip, injectors, turbo, air intake, and some things u guys already said like a fuel system, gauges, ect...
Old 07-03-2010, 05:45 PM
Ozoneburner90's Avatar
once you have the small stuff like a fuel system and guages, then build up. start out with an exhaust, then an intake, chip, injectors, and lastly, a turbo.
Old 07-03-2010, 06:14 PM
nickg's Avatar
fuel system
exhaust
chip with gauges
injectors
turbo
Old 07-04-2010, 02:21 AM
Midnite's Avatar
Chips are for Fords. Our Dodges use fuel/timing boxes that plug into the MAP and data link harnesses, and some tap the pump wire.
If adding nothing more than a box, then you generally don't need to worry about the transmission. If the box taps the pump wire then it can add 100+ hp and is a different story. Otherwise you're only talking about 30 or so hp, and that's nothing to worry about with regard to the tranny.
For what you're talking about though, you definitely need to put some money into the transmission. At the minimum, a better torque converter and valve body will do quite a bit. For serious power, a full rebuild with parts from someone like DTT, ATS or Goerend is the only way to do it.
Here's what I'd go with, and in this order:
Gauges (fuel pressure, boost, EGT)
Lift pump replacement (FASS or Airdog)
Intake and exhaust
Fuel/timing box (old school would be an Edge Comp, a Smarty programmer would be good though)
Formula 1 Mach series injectors (I have Mach 1s and make a solid 375 hp with my Comp)
Transmission work
Turbo
Cam
Here's what I have in my 2000 with a manual tranny:
Gauges
FASS 150
Stock exhaust w/ muffler replaced with straight pipe
Edge Comp (pump wire tapped)
Mach 1 injectors
Southbend Con FE clutch
PDR hybrid HX-35/40 turbo
My setup gives extremely streetable power and awesome fuel mileage, great exhaust temps when towing, and at the same time attracts seriously hot women. Okay, that last part may only be in my mind.
In the end it all boils down to how much money you want to spend.
Mike
Old 07-04-2010, 01:59 PM
How many GPH do i need on my fuel system. And how big of turbo should i get?
Old 07-06-2010, 05:39 PM
Brendan's Avatar
That last question depends on how much power you want and what you use it for. you answer those questions and we can help
gergthegreat
12-30-2008 09:19 PM
bansh-eman
01-27-2008 02:48 AM
Elk_Hunter
10-24-2006 03:17 PM
cowdude
02-19-2003 06:20 PM
Quick Reply: should i chip my truck?
