sensor on air intake hose????
Old 07-18-2003, 11:41 AM
Mule's Avatar
I'm doing the BHAF (AH19002) and am using a 4&quot; pipe for the connection between the filter and flex line. There is a sensor on the stock air box that is going to have to be mounted to the 4&quot; pipe. What is this sensor for and is it going to mess with it if I mount it to the pipe? It looks like a vacuume sender to me. ???<br><br>Yeah I know, I'm beatin the filter thing to death. :P I just don't want to use an oiled filter on the roads I travel.<br><br>Thanks<br>Mule
Old 07-18-2003, 04:51 PM
phox_mulder's Avatar
Re:sensor on air intake hose????
I do believe that is the IAT sensor.<br>(Intake Air Temp).<br><br>Its either that or the filter minder sucky downy thingy, but it wouldn't have wires connected to it.<br><br><br>phox
Old 07-18-2003, 05:12 PM
dodgedude361's Avatar
<br><br>Is that the Official term?
Old 07-21-2003, 01:28 AM
Push Rod's Avatar
Location: Drive till ya hit a Polar Bear, then go back 50 miles
IAT/AP Sensor (Intake Air Temp/Air Pressure). You'll definitely want to get that critter in the pipe after the BHAF. As long as you don't draw any kind of vacuum, the aftermarket system will help the ECM maintain proper fueling levels (the ECM defuels as that sensor detects lower pressure).<br><br>Rod
MedicShawn
11-14-2010 08:10 PM
herb
07-18-2008 08:25 AM
Strjock81
02-03-2007 11:19 PM
george7941
08-10-2005 07:06 PM
Quick Reply: sensor on air intake hose????
